Re: [cgal-discuss] how to obtain surface triangles from delaunay_3d triangulation
- To:
- Subject: Re: [cgal-discuss] how to obtain surface triangles from delaunay_3d triangulation
- Date: Fri, 29 Nov 2013 12:04:47 -0800 (PST)
putting it this way, i hope the read will get what i intend to achieve. if i
have a point cloud (from a scan of building) and triangulate a subset(could
be points from the same surface of the building or points from 2 or even
more intersecting surfaces) of this cloud using DT. i want to be able to
retrieve among all the incident facets on a specified vertex, facets that
form a triangular fan around this vertex. i tried
convex_hull_3_to_polyhedron_3 function and through this i can get what i
want for at least about 25% of my points but the remaining percentages could
not be accessed using this approach.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/how-to-obtain-surface-triangles-from-delaunay-3d-triangulation-tp4658143p4658495.html
- Re: [cgal-discuss] how to obtain surface triangles from delaunay_3d triangulation, Sebastien Loriot (GeometryFactory), 11/13/2013
- Re: [cgal-discuss] how to obtain surface triangles from delaunay_3d triangulation, Thijs van Lankveld, 11/13/2013
- Re: [cgal-discuss] how to obtain surface triangles from delaunay_3d triangulation, loc, 11/29/2013
