- To:
- Subject: [cgal-discuss] Use a set of implicit surfaces as arrangements in 3D
- Date: Thu, 21 Nov 2013 10:41:22 -0800 (PST)
Dear forum,
I am currently working on a problem to identify a set of most significat
implicit surfaces in a 3D scene/object. After I have identified them I would
like to construct a watertight surface using the elements.
I have a feeling, that it might be solvable using CGAL with arrangements.
However, I do not have a deep insight into the framework to be able to say
if this is possible.
Could someone please give me a hint, if there is a module which can help me
to solve the problem.
Thank you very much!
Eugen
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Use-a-set-of-implicit-surfaces-as-arrangements-in-3D-tp4658453.html
- [cgal-discuss] Use a set of implicit surfaces as arrangements in 3D, mojovski, 11/21/2013
