- To:
- Subject: Re: [cgal-discuss] NN, change the splitting rule of the tree
- Date: Thu, 21 Nov 2013 10:52:22 -0800 (PST)
Well, the code you provided will make my min. example to, but when one runs
it, he will receive a "Segmentation fault (core dumped)". I changed the
SplitingRule to the Sliding_midpoint and it worked as expected!
Median_of_rectangle worked too, but Midpoint_of_rectangle gave a seg fault
too!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/NN-change-the-splitting-rule-of-the-tree-tp4658440p4658454.html
- [cgal-discuss] NN, change the splitting rule of the tree, Samaras, 11/20/2013
- Re: [cgal-discuss] NN, change the splitting rule of the tree, Philipp Moeller, 11/20/2013
- Re: [cgal-discuss] NN, change the splitting rule of the tree, Samaras, 11/20/2013
- Re: [cgal-discuss] NN, change the splitting rule of the tree, Philipp Moeller, 11/21/2013
- Re: [cgal-discuss] NN, change the splitting rule of the tree, Samaras, 11/21/2013
