- To:
- Subject: Re: [cgal-discuss] Having problem installing CGAL library
- Date: Fri, 22 Nov 2013 00:52:34 -0800 (PST)
thanks Sebastian for the info. I followed that tutorial as well but my
question is that during boost installation do I have to install both version
boost 1_54_0 and 1_49_0 as in the tutorial it is indicated "You then need to
set the following two environment variables to point respectively to the
path of the libraries and the headers:"
BOOST_LIBRARYDIR=C:\dev\libboost_1_54_0\lib32-msvc-11.0
BOOST_INCLUDEDIR=C:\dev\boost_1_49_0
and also in the tutorial he installed boost in this directory
"c:\local\boost_1_54_0" but set the environment variables in
"C:\dev\boost_1_49_0". This is really confusing. Can you please help me out
what should I follow?
Thanks once again and hoping for your reply soon.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Having-problem-installing-CGAL-library-tp4658447p4658459.html
- Re: [cgal-discuss] Having problem installing CGAL library, naim, 11/21/2013
- Re: [cgal-discuss] Having problem installing CGAL library, Sebastien Loriot (GeometryFactory), 11/22/2013
- Re: [cgal-discuss] Having problem installing CGAL library, naim, 11/22/2013
- Re: [cgal-discuss] Having problem installing CGAL library, Laurent Rineau (CGAL/GeometryFactory), 11/22/2013
- Re: [cgal-discuss] Having problem installing CGAL library, Laurent Rineau (CGAL/GeometryFactory), 11/25/2013
