- To:
- Subject: Re: [cgal-discuss] Having problem installing CGAL library
- Date: Fri, 22 Nov 2013 10:30:42 +0100
Le vendredi 22 novembre 2013 00:52:34 naim a écrit :
> thanks Sebastian for the info. I followed that tutorial as well but my
> question is that during boost installation do I have to install both version
> boost 1_54_0 and 1_49_0 as in the tutorial it is indicated "You then need
> to set the following two environment variables to point respectively to the
> path of the libraries and the headers:"
> BOOST_LIBRARYDIR=C:\dev\libboost_1_54_0\lib32-msvc-11.0
> BOOST_INCLUDEDIR=C:\dev\boost_1_49_0
> and also in the tutorial he installed boost in this directory
> "c:\local\boost_1_54_0" but set the environment variables in
> "C:\dev\boost_1_49_0". This is really confusing. Can you please help me out
> what should I follow?
> Thanks once again and hoping for your reply soon.
That is my fault. This summer, while preparing the release CGAL-4.3, I have
updated that tutorial to a new version of Boost, but I did it partially.
The web page is updated now. The variables are:
BOOST_INCLUDEDIR=C:\dev\libboost_1_54_0
Laurent Rineau, PhD
- Re: [cgal-discuss] Having problem installing CGAL library, naim, 11/21/2013
- Re: [cgal-discuss] Having problem installing CGAL library, Sebastien Loriot (GeometryFactory), 11/22/2013
- Re: [cgal-discuss] Having problem installing CGAL library, naim, 11/22/2013
- Re: [cgal-discuss] Having problem installing CGAL library, Laurent Rineau (CGAL/GeometryFactory), 11/22/2013
- Re: [cgal-discuss] Having problem installing CGAL library, Laurent Rineau (CGAL/GeometryFactory), 11/25/2013
