- To:
- Subject: Re: [cgal-discuss] Alpha_Shapes_3 Bunny
- Date: Wed, 27 Nov 2013 10:26:53 +0100
Hi Claudia
except if the shape is particularly well sampled, there is usually no satisfying result when reconstructing with an alpha shape... it will either have holes or be "too large" or probably even both at the same time. As Mariette already sayd, this is not a good reconstruction method.
remarks about the size of your triangles:
- what you call "the" circumscribing sphere of a triangle in 3d is not uniquely defined, the alpha shape deals with one of the spheres passing through the 3 vertices of the triangle
- the max radius is sqrt(alpha) = 0.036... in your case
an edge length is at most the diameter = 0.072
so, your 0,055 is not surprising at all
best,
Monique Teillaud
http://www.inria.fr/sophia/members/Monique.Teillaud/
INRIA Sophia Antipolis - Méditerranée
Institut National de Recherche en Informatique et Automatique
Le 26/11/13 21:01, Claudia Werner a écrit :
Thanks so far.
I already "played" with different alpha-values but couldn't find a
sattifying result. I either get holes in the bunny or the ears are
connected by other triangles. Especially this (wrong) triangles are the
triangles I am wondering about. As far as I understood, a facet of the
Delaunay-Triangulation is part of the alpha-shape iff its circumsphere
is empty and has a radius smaler than alpha. But the radius of the
circumsphere of the triangles between the ears of the bunny have a
radius mush greater than alpha, so why aren't this triangles deleted?
E.g. when using alpha-opt = 0,0013... there are still triangles with
edge-length around 0,055 otherwise mush smaler triangles are "deleted"
Best,
Claudia
----- Ursprüngliche Mail -----
Von: "Daniel Duque"
An:
Gesendet: Dienstag, 26. November 2013 10:42:09 GMT +01:00
Amsterdam/Berlin/Bern/Rom/Stockholm/Wien
Betreff: Re: [cgal-discuss] Alpha_Shapes_3 Bunny
Hi,
I don't know much about the bunny, but if it's a nearly-regular mesh,
with a well defined mean distance
between surface nodes, d, you should go for alpha values around, but
larger than, d^2.
Best,
Daniel
On Tue, Nov 26, 2013 at 10:30 AM, Mariette Yvinec
<mailto:>>
wrote:
Plain alpha_shapes is not a very good reconstruction method.
The "optimal" alpha-value is the smallest alpha value
that will give a single connected components including all data points.
It might not be the best one to see the Bunny feature appear.
You might try a few others alpha values,
just to be convinced things are working as they should.
Le 25/11/13 20:28, Claudia Werner a écrit :
Dear all,
I am working on Alpha_Shapes for triangulating a point cloud. As a first
example I tried the example "Alpha_shapes_3/ex_alpha_shapes_3.cpp"
(http://doc.cgal.org/latest/Alpha_shapes_3/Alpha_shapes_3_2ex_alpha_shapes_3_8cpp-example.html)
and wrote the result to an off-File as descirbed
here:http://stackoverflow.com/questions/15905833/saving-cgal-alpha-shape-surface-mesh.
Displaying the result with MeshLab (using the off-file), I was
wondering about the result (see attached picture).
Has anybody an idea why I don't get a better result? As in the
example I used the optimal alpha.
I also attached the cpp-file.
Best Regards and thanks for your help,
Claudia
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
Monique Teillaud
- AW: [cgal-discuss] Alpha_Shapes_3 Bunny, Claudia Werner, 11/26/2013
- Re: [cgal-discuss] Alpha_Shapes_3 Bunny, Monique Teillaud, 11/27/2013
