cgal-discuss - [cgal-discuss] CGAL 4.2 4.3: Surface mesher: Polyhedral_surface_3
  • To:
  • Subject: [cgal-discuss] CGAL 4.2 4.3: Surface mesher: Polyhedral_surface_3
  • Date: Wed, 27 Nov 2013 10:47:47 +0100
Dear CGALs,
We're having some troubles updating our code to CGAL 4.3:
While changelog says the way we did is now (only) deprecated**, I cannot
compile successfully.
Our CGAL tool (included in OpenMEEG (Athena Team)) aims at giving us a
surfacic mesh with either a 3D grey-level image, implicit functions, or
polyhedron as input.
When giving a polyhedron, it should re-mesh it.
That is the part causing troubles at compilation time (see attached
files).
We want to solve this problem; the documentation says:
example Surface_mesher/polyhedron_remesher.cpp
and does
#include <CGAL/Polyhedral_surface_3.h>
These files do not exist... neither in CGAL 4.2 nor 4.3.
Attached files contains our short tool (which compile on 4.2
successfully) and the build log with CGAL 4.3.
We would appreciate any help on our tool or at least completing the
documentation/examples of your Surface_mesher.
Thank you and best regards
Emmanuel
** changelog:
"Introduce the class AABB_face_graph_triangle_primitive which replaces
the class AABB_polyhedron_triangle_primitive (which is now deprecated)."
Project Name : OpenMEEG
© INRIA and ENPC (contributors: Geoffray ADDE, Maureen CLERC, Alexandre
GRAMFORT, Renaud KERIVEN, Jan KYBIC, Perrine LANDREAU, Théodore PAPADOPOULO,
Emmanuel OLIVI
Maureen.Clerc.AT.sophia.inria.fr, keriven.AT.certis.enpc.fr,
kybic.AT.fel.cvut.cz, papadop.AT.sophia.inria.fr)
The OpenMEEG software is a C++ package for solving the forward/inverse
problems of electroencephalography and magnetoencephalography.
This software is governed by the CeCILL-B license under French law and
abiding by the rules of distribution of free software.  You can  use,
modify and/ or redistribute the software under the terms of the CeCILL-B
license as circulated by CEA, CNRS and INRIA at the following URL
"http://www.cecill.info";.
As a counterpart to the access to the source code and  rights to copy,
modify and redistribute granted by the license, users are provided only
with a limited warranty  and the software's authors,  the holders of the
economic rights,  and the successive licensors  have only  limited
liability.
In this respect, the user's attention is drawn to the risks associated
with loading,  using,  modifying and/or developing or reproducing the
software by the user in light of its specific status of free software,
that may mean  that it is complicated to manipulate,  and  that  also
therefore means  that it is reserved for developers  and  experienced
professionals having in-depth computer knowledge. Users are therefore
encouraged to load and test the software's suitability as regards their
requirements in conditions enabling the security of their systems and/or
data to be ensured and,  more generally, to use and operate it in the
same conditions as regards security.
The fact that you are presently reading this means that you have had
knowledge of the CeCILL-B license and that you accept its terms.
#include "mesh.h"
#include <assert.h>
#include "options.h"
#include "cgal_mesh_include.h"
#include <CGAL/IO/Complex_2_in_triangulation_3_file_writer.h>
using namespace OpenMEEG;
int main(int argc, char **argv) {
    command_usage("Create a BEM mesh from either a very fine mesh, a 3D image (.inr format v4), or sphere (no input file):");
    const char * input_filename  = command_option("-i",(const char *) NULL,"Input image or mesh");
    const bool   inout           = command_option("-inout",false,"Inside out the image ?");
    const double radius_bound    = command_option("-fs",1e-1,"facet radius bound of elements");
    const double distance_bound  = command_option("-fd",1e-1,"facet distance bound to the input surface");
    const char * output_filename = command_option("-o",(const char *) NULL,"Output Mesh");
    const double sphere_radius   = command_option("-r", 0., "radius of the sphere");
    const double hemisphere_radius = command_option("-hr", 0., "radius of the hemisphere");
    const unsigned init_points   = command_option("-ip", 10, "initial number of points");
    if ( command_option("-h",(const char *)0,0) ) {
        return 0;
    if ( output_filename == NULL ) {
        std::cerr << "Set an output filename" << std::endl;
        return 0;
    Gray_level_image *image;
    Tr tr;           // 3D-Delaunay triangulation
    C2t3 c2t3(tr);   // 2D-complex in 3D-Delaunay triangulation
    // Mesh criteria
    double angle_bound = 30.; // angle bound for the triangular elements (not less than 30 degree)
    if ( input_filename != NULL ) {
        std::string extension = getNameExtension(input_filename);
        if ( extension == "inr" || extension == "inr4" ) {
            bool positive_inside  = inout;
            double value_outside  = 1.;
            double levelset_value = 0.;
            image = new Gray_level_image(input_filename,levelset_value,positive_inside,value_outside);
            std::cout << "Input INR image:\n dimension: " << image->xdim() << "x"<< image->ydim() << "x"<< image->zdim() << std::endl;
            // Carefully choose bounding sphere: the center must be inside the
            // surface defined by 'image' and the radius must be high enough so that
            // the sphere actually bounds the whole image.
            Point_3 bounding_sphere_center(image->xdim()/2., image->ydim()/2., image->zdim()/2.);
            Geom_traits::FT bounding_sphere_squared_radius = image->xdim()*image->ydim()*2.;
            Geom_traits::Sphere_3 bounding_sphere(bounding_sphere_center, bounding_sphere_squared_radius);
            // definition of the surface, with 10^-5 as relative precision
            GreySurface_3 surface(*image, bounding_sphere, 1e-8);
            CGAL::Surface_mesh_default_criteria_3<Tr> criteria(angle_bound, radius_bound, distance_bound);
            CGAL::make_surface_mesh(c2t3, surface, criteria, CGAL::Manifold_tag()); // make the surfacic mesh with a manifold criteria
        } else {
            Mesh m_in(input_filename, false);
            std::cout << "Input surface:\n nb of points: " << m_in.nb_vertices() << "\t nb of triangles:\t" << m_in.nb_triangles() << std::endl;
            // Create input polyhedron
            Polyhedron polyhedron;
            for ( Mesh::const_iterator tit = m_in.begin(); tit != m_in.end(); ++tit) {
                const Vertex p1 = tit->s1();
                const Vertex p2 = tit->s2();
                const Vertex p3 = tit->s3();
                polyhedron.make_triangle(Point_3(p1.x(), p1.y(), p1.z()), Point_3(p2.x(), p2.y(), p2.z()), Point_3(p3.x(), p3.y(), p3.z()));
            Input_surface input_surf(polyhedron);
            unsigned nb_initial_points = 5;
            unsigned i = 0;
            for ( Polyhedron::Vertex_iterator it = polyhedron.vertices_begin(); it != polyhedron.vertices_end(), i < nb_initial_points; it++, i++) {
                if ( i%m_in.nb_vertices() / 5 == 0 ) {
                    tr.insert(it->point());
            // Mesh generation
            CGAL::make_surface_mesh(c2t3, input_surf, input_surf, criteria, CGAL::Manifold_tag()); // make the surfacic mesh with a manifold criteria
    } else { // implicit functions (sphere or hemisphere)
        if ( sphere_radius > 0.0001 ) {
            SphereFunction spherefunction(std::pow(sphere_radius, 2));
            // defining the surface
            SphereSurface_3 surface(spherefunction,             // pointer to function
                    Geom_traits::Sphere_3(CGAL::ORIGIN, std::pow(2.*sphere_radius, 2))); // bounding sphere
            // defining meshing criteria
            CGAL::Surface_mesh_default_criteria_3<Tr> criteria(angle_bound,  // angular bound
                    radius_bound,  // radius bound
                    distance_bound); // distance bound
            // meshing surface
        } else if ( hemisphere_radius > 0.0001 ) { // bug and too many point close to the origin (0, 0, 0) if BB is centered there
            HemiSphereFunction hspherefunction(std::pow(hemisphere_radius, 2));
            HemiSphereSurface_3 surface(hspherefunction,             // pointer to function
                    Geom_traits::Sphere_3(Tr::Point(0, 0, hemisphere_radius/2.), std::pow(2.*hemisphere_radius, 2))); // bounding sphere
            // Setting initial points on the circle
            unsigned init_points2 = init_points;
            if ( 2.*M_PI*hemisphere_radius/init_points > radius_bound ) {
                init_points2 = unsigned(2.*M_PI*hemisphere_radius / radius_bound);
                std::cout << "Increasing nb of initial points from " << init_points << " to " << init_points2 << std::endl;
            for ( unsigned iip = 1; iip <= init_points2; ++iip) {
                Tr::Point p = Tr::Point(hemisphere_radius*std::cos(2.*M_PI/init_points2*iip), hemisphere_radius*std::sin(2.*M_PI/init_points2*iip) , 0);
                tr.insert(p);
            // meshing surface
            CGAL::make_surface_mesh(c2t3, surface, criteria, CGAL::Manifold_tag(), 10); // 10 is nb of initial point (chosen by CGAL!...)
            // project the disk point on the x-y plane (i.e assign a 0 z-coordinate strictly)
            for ( Tr::Finite_vertices_iterator vit = c2t3.triangulation().finite_vertices_begin(), end = c2t3.triangulation().finite_vertices_end(); vit != end; ++vit)
                Point_3& p = vit->point();
                double d_sphere = (std::pow(p.x(), 2) + std::pow(p.y(), 2) + std::pow(p.z(), 2) - hemisphere_radius);
                if ( ( std::abs(p.z()) < std::min(distance_bound, radius_bound) ) && ( d_sphere < std::min(distance_bound, radius_bound)) ) {
                    p = Point_3(p.x(), p.y(), 0);
    Mesh m_out = CGAL_to_OM(c2t3);
    m_out.update();
    m_out.save(output_filename);
    m_out.info();
    return 0;
   Emmanuel OLIVI
   liability.
#ifndef OPENMEEG_CGAL_MESH_INCLUDE_H
#define OPENMEEG_CGAL_MESH_INCLUDE_H
// for verbosity
#define CGAL_SURFACE_MESHER_VERBOSE
#include <CGAL/Mesh_3/Robust_intersection_traits_3.h>
#include <CGAL/Surface_mesh_default_triangulation_3.h>
#include <CGAL/Complex_2_in_triangulation_3.h>
#include <CGAL/Surface_mesh_traits_generator_3.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/AABB_tree.h>
#include <CGAL/AABB_traits.h>
#include <CGAL/AABB_polyhedron_triangle_primitive.h>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Gray_level_image_3.h>
#include <CGAL/Implicit_surface_3.h>
#include <CGAL/make_surface_mesh.h>
// Domain
// (we use exact intersection computation with Robust_intersection_traits_3)
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Mesh_3::Robust_intersection_traits_3<K> Geom_traits;
typedef Geom_traits::Point_3 Point_3;
typedef CGAL::Polyhedron_3<K> Polyhedron;
typedef CGAL::Gray_level_image_3<Geom_traits::FT, Point_3> Gray_level_image;
typedef CGAL::Simple_cartesian<double> Simple_cartesian_kernel;
typedef CGAL::Implicit_surface_3<Geom_traits, Gray_level_image> GreySurface_3;
// Triangulation
typedef CGAL::Surface_mesh_default_triangulation_3 Tr;
typedef CGAL::Complex_2_in_triangulation_3<Tr> C2t3;
typedef Tr::Vertex_handle Vertex_handle;
typedef Tr::Geom_traits GT;
// from polygons
namespace CGAL {
    template <class Polyhedron, class Kernel, class Dummy_kernel> class AABB_polyhedral_oracle;
typedef CGAL::AABB_polyhedral_oracle<Polyhedron,K,Simple_cartesian_kernel> Input_surface;
// sphere function
// for spheres
template <typename FT, typename Point>
class FT_to_point_Sphere_wrapper : public std::unary_function<Point, FT>
    double sqrd;
    public:
    FT_to_point_Sphere_wrapper(FT sqrd_) : sqrd(sqrd_) {}
    FT operator()(Point p) const { return (std::pow(p.x(),2)+std::pow(p.y(),2)+std::pow(p.z(),2)-sqrd); }
typedef FT_to_point_Sphere_wrapper<K::FT, K::Point_3> SphereFunction;
typedef CGAL::Implicit_surface_3<Geom_traits, SphereFunction> SphereSurface_3;
// Hemisphere function
class FT_to_point_HemiSphere_wrapper : public std::unary_function<Point, FT>
    double sqrd;
    public:
    FT_to_point_HemiSphere_wrapper(FT sqrd_) : sqrd(sqrd_) {}
        double d_sphere = (std::pow(p.x(), 2) + std::pow(p.y(), 2) + std::pow(p.z(), 2) - sqrd);
        double d_total;
        if ( p.z() > 0 ) {
            d_total = ( d_sphere > 0 ) ? d_sphere : -std::min(-d_sphere, std::pow(p.z(), 2));
        } else {
            d_total = std::min(std::pow(p.x(), 2), sqrd ) + std::min(std::pow(p.y(), 2), sqrd ) + std::pow(p.z(), 2);
        return d_total;
typedef FT_to_point_HemiSphere_wrapper<K::FT, K::Point_3> HemiSphereFunction;
typedef CGAL::Implicit_surface_3<Geom_traits, HemiSphereFunction> HemiSphereSurface_3;
namespace CGAL {
    // class dealing a surface as an input for the surface mesher (or building an oracle from the input surface)
        class AABB_polyhedral_oracle {
            public:
                typedef typename Kernel::FT FT;
                typedef typename Kernel::Ray_3 Ray_3;
                typedef typename Kernel::Line_3 Line_3;
                typedef typename Kernel::Point_3 Point_3;
                typedef typename Kernel::Segment_3 Segment_3;
                typedef AABB_polyhedral_oracle<Polyhedron,Kernel,Dummy_kernel> Self;
                typedef Self Surface_mesher_traits_3;
                typedef Point_3 Intersection_point;
                typedef Self Surface_3;
                // AABB tree
                // #if CGAL version <= 4.2
                typedef AABB_const_polyhedron_triangle_primitive<Kernel, Polyhedron> AABB_primitive;
                // #else
                // typedef AABB_face_graph_triangle_primitive<Polyhedron> AABB_primitive;
                // #endif
                typedef class AABB_traits<Kernel,AABB_primitive> AABB_traits;
                typedef AABB_tree<AABB_traits> Tree;
                typedef typename AABB_traits::Bounding_box Bounding_box;
                typedef boost::shared_ptr<Tree> Tree_shared_ptr;
                Tree_shared_ptr m_pTree;
                Tree* tree() const { return m_pTree.get(); }
                // Surface constructor
                AABB_polyhedral_oracle(const Polyhedron& poly) : m_pTree(Tree_shared_ptr(new Tree(poly.facets_begin(), poly.facets_end()))) { }
                AABB_polyhedral_oracle(const AABB_polyhedral_oracle& oracle) : m_pTree(oracle.m_pTree) { }
                class Intersect_3;
                friend class Intersect_3;
                class Intersect_3 {
                    typedef boost::optional<typename Tree::Object_and_primitive_id> AABB_intersection;
                    const Self& self;
                    public:
                    Intersect_3(const Self& self_) : self(self_) { }
                    Object operator()(const Surface_3& surface, const Segment_3& segment) const
                        AABB_intersection intersection = surface.tree()->any_intersection(segment);
                        if ( intersection )
                            return intersection->first;
                        else
                            return Object();
                    Object operator()(const Surface_3& surface, const Ray_3& ray) const
                        AABB_intersection intersection = surface.tree()->any_intersection(ray);
                        if ( intersection )
                        else
                            return Object();
                    Object operator()(const Surface_3& surface, const Line_3& line) const
                        AABB_intersection intersection = surface.tree()->any_intersection(line);
                        if ( intersection )
                        else
                            return Object();
                Intersect_3 intersect_3_object() const
                    return Intersect_3(*this);
                class Construct_initial_points;
                friend class Construct_initial_points;
                    const Self& self;
                    public:
                    Construct_initial_points(const Self& self_) : self(self_)
                    template <typename OutputIteratorPoints>
                        OutputIteratorPoints operator() (const Surface_3, OutputIteratorPoints out, int ) const
                            return out;
                Construct_initial_points construct_initial_points_object() const
                    return Construct_initial_points(*this);
                template <class P>
                    bool is_in_volume(const Surface_3& surface, const P& p)
                        const Bounding_box bbox = surface.tree()->root_bbox();
                        if (p.x() < bbox.xmin() || p.x() > bbox.xmax()) {
                            return false;
                        if (p.y() < bbox.ymin() || p.y() > bbox.ymax()) {
                            return false;
                        if (p.z() < bbox.zmin() || p.z() > bbox.zmax()) {
                            return false;
                        const double diameter = max_bbox_length(bbox) * 2;
                        typename CGAL::Random_points_on_sphere_3<Point_3> random_point(FT(1));
                        typename Kernel::Construct_vector_3 vector = Kernel().construct_vector_3_object();
                        typename Kernel::Construct_segment_3 segment = Kernel().construct_segment_3_object();
                        typename Kernel::Construct_translated_point_3 translate = Kernel().construct_translated_point_3_object();
                        typename Kernel::Construct_scaled_vector_3 scale = Kernel().construct_scaled_vector_3_object();
                        const Segment_3 seg = segment(p, translate(p, scale(vector(ORIGIN, *random_point), diameter)));
                        return (surface.tree()->number_of_intersections(seg) % 2) == 1;
            private:
                double max_bbox_length(const Bounding_box& bbox) const
                    return (std::max)(bbox.xmax()-bbox.xmin(),
                            (std::max)(bbox.ymax()-bbox.ymin(),
                                bbox.zmax()-bbox.zmin()));
        }; // end class AABB_polyhedral_oracle
} // end namespace CGAL
OpenMEEG::Mesh CGAL_to_OM(C2t3 c2t3) {
    OpenMEEG::Mesh m(c2t3.triangulation().number_of_vertices(), c2t3.number_of_facets());
    std::map<Vertex_handle, unsigned> V;
    unsigned inum = 0;
        const Point_3& p = vit->point();
        m.add_vertex(OpenMEEG::Vertex(CGAL::to_double(p.x()), CGAL::to_double(p.y()), CGAL::to_double(p.z())));
        V[vit] = inum++;
    Tr::Finite_facets_iterator fit = c2t3.triangulation().finite_facets_begin();
    C2t3::Facets oriented_set;
    std::stack<C2t3::Facet> stack;
    Tr::size_type number_of_facets = c2t3.number_of_facets();
    while ( oriented_set.size() != number_of_facets )
        while ( fit->first->is_facet_on_surface(fit->second) == false || oriented_set.find(*fit) != oriented_set.end() || oriented_set.find(c2t3.opposite_facet(*fit)) != oriented_set.end() ) {
            ++fit;
        oriented_set.insert(*fit);
        stack.push(*fit);
        while ( ! stack.empty() ) {
            C2t3::Facet f = stack.top();
            stack.pop();
            for ( unsigned ih = 0 ; ih < 3 ; ++ih) {
                const int i1  = c2t3.triangulation().vertex_triple_index(f.second, c2t3.triangulation().cw(ih));
                const int i2  = c2t3.triangulation().vertex_triple_index(f.second, c2t3.triangulation().ccw(ih));
                const C2t3::Face_status face_status = c2t3.face_status(C2t3::Edge(f.first, i1, i2));
                if ( face_status == C2t3::REGULAR) {
                    C2t3::Facet fn = c2t3.neighbor(f, ih);
                    if ( oriented_set.find(fn) == oriented_set.end() ) {
                        if ( oriented_set.find(c2t3.opposite_facet(fn)) == oriented_set.end() )
                            oriented_set.insert(fn);
                            stack.push(fn);
                        // } else { success = false; // non-orientable
                // else if ( face_status != C2t3::BOUNDARY ) { success = false; // non manifold, thus non-orientable }
            } // end "for each neighbor of f"
        } // end "stack non empty"
    } // end "oriented_set not full"
    inum = 0;
    for ( C2t3::Facets::const_iterator fcit = oriented_set.begin(); fcit != oriented_set.end(); ++fcit) {
        const Tr::Cell_handle cell = fcit->first;
        const int& index = fcit->second;
        const int index1 = V[cell->vertex(c2t3.triangulation().vertex_triple_index(index, 0))];
        const int index2 = V[cell->vertex(c2t3.triangulation().vertex_triple_index(index, 1))];
        const int index3 = V[cell->vertex(c2t3.triangulation().vertex_triple_index(index, 2))];
        OpenMEEG::Triangle t(m.vertices()[index1], m.vertices()[index2], m.vertices()[index3] );
        m.push_back(t);
    return m;
#endif  //! OPENMEEG_CGAL_MESH_INCLUDE_H
[  0%] Built target arithchk
[  6%] Built target f2c
[ 11%] Built target blas
[ 59%] Built target lapack
[ 60%] Built target matio
[ 60%] Built target OpenMEEGMaths
[ 60%] Built target om_assemble
[ 60%] Built target om_forward
[ 60%] Built target om_gain
[ 60%] Built target om_minverser
[ 60%] Built target om_add_vtk_dataset
[ 60%] Building CXX object tools/CMakeFiles/om_cgal_mesh_create.dir/cgal_mesh_create.cpp.o
In file included from /home/manolivi/local/include/CGAL/AABB_polyhedron_triangle_primitive.h:27:0,
                 from /home/manolivi/src/openmeegEOlivi/tools/cgal_mesh_include.h:57,
                 from /home/manolivi/src/openmeegEOlivi/tools/cgal_mesh_create.cpp:43:
/home/manolivi/local/include/CGAL/internal/deprecation_warning.h:57:6: attention : #warning "A deprecated header has been included." [-Wcpp]
/home/manolivi/local/include/CGAL/internal/deprecation_warning.h:58:54: note: #pragma message: Warning: The header <CGAL/AABB_polyhedron_triangle_primitive.h> is deprecated. Please use <CGAL/AABB_face_graph_triangle_primitive.h> instead.
In file included from /home/manolivi/src/openmeegEOlivi/tools/cgal_mesh_create.cpp:43:0:
/home/manolivi/src/openmeegEOlivi/tools/cgal_mesh_include.h: In instantiation of ‘CGAL::Object CGAL::AABB_polyhedral_oracle<Polyhedron, Kernel, Dummy_kernel>::Intersect_3::operator()(const Surface_3&, const Segment_3&) const [with Polyhedron = CGAL::Polyhedron_3<CGAL::Epick>; Kernel = CGAL::Epick; Dummy_kernel = CGAL::Simple_cartesian<double>; CGAL::AABB_polyhedral_oracle<Polyhedron, Kernel, Dummy_kernel>::Surface_3 = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >; CGAL::AABB_polyhedral_oracle<Polyhedron, Kernel, Dummy_kernel>::Segment_3 = CGAL::Segment_3<CGAL::Epick>]’:
/home/manolivi/local/include/CGAL/Surface_mesher/Surface_mesher.h:596:9:   required from ‘bool CGAL::Surface_mesher::Surface_mesher_base<C2T3, Surface_, SurfaceMeshTraits, Criteria_>::is_facet_on_surface(const Facet&, CGAL::Surface_mesher::Surface_mesher_base<C2T3, Surface_, SurfaceMeshTraits, Criteria_>::Point&) [with C2T3 = CGAL::Complex_2_in_triangulation_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >; Surface_ = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >; SurfaceMeshTraits = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >; Criteria_ = CGAL::Surface_mesh_default_criteria_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >; CGAL::Surface_mesher::Surface_mesher_base<C2T3, Surface_, SurfaceMeshTraits, Criteria_>::Facet = std::pair<CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > > >, CGAL::Default>, false>, int>; CGAL::Surface_mesher::Surface_mesher_base<C2T3, Surface_, SurfaceMeshTraits, Criteria_>::Point = CGAL::Point_3<CGAL::Epick>]’
/home/manolivi/local/include/CGAL/Surface_mesher/Surface_mesher.h:175:4:   required from ‘void CGAL::Surface_mesher::Surface_mesher_base<C2T3, Surface_, SurfaceMeshTraits, Criteria_>::scan_triangulation_impl() [with C2T3 = CGAL::Complex_2_in_triangulation_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >; Surface_ = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >; SurfaceMeshTraits = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >; Criteria_ = CGAL::Surface_mesh_default_criteria_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >]’
/home/manolivi/local/include/CGAL/Surface_mesher/Surface_mesher_regular_edges.h:234:7:   required from ‘void CGAL::Surface_mesher::Surface_mesher_regular_edges_base<C2T3, Surface, SurfaceMeshTraits, Criteria, withBoundary>::scan_triangulation_impl() [with C2T3 = CGAL::Complex_2_in_triangulation_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >; Surface = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >; SurfaceMeshTraits = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >; Criteria = CGAL::Surface_mesh_default_criteria_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >; bool withBoundary = false]’
/home/manolivi/local/include/CGAL/Surface_mesher/Surface_mesher_manifold.h:159:2:   required from ‘void CGAL::Surface_mesher::Surface_mesher_manifold_base<C2T3, Surface, SurfaceMeshTraits, Criteria, SMMBB>::scan_triangulation_impl() [with C2T3 = CGAL::Complex_2_in_triangulation_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >; Surface = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >; SurfaceMeshTraits = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >; Criteria = CGAL::Surface_mesh_default_criteria_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >; SMMBB = CGAL::Surface_mesher::Surface_mesher_regular_edges_base<CGAL::Complex_2_in_triangulation_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::Surface_mesh_default_criteria_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, false>]’
/home/manolivi/local/include/CGAL/Mesher_level.h:165:5:   required from ‘void CGAL::Mesher_level<Tr, Derived, Element, Previous, Triangulation_traits>::scan_triangulation() [with Tr = CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default>; Derived = CGAL::Surface_mesher::Surface_mesher<CGAL::Surface_mesher::Surface_mesher_manifold_base<CGAL::Complex_2_in_triangulation_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::Surface_mesh_default_criteria_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, CGAL::Surface_mesher::Surface_mesher_regular_edges_base<CGAL::Complex_2_in_triangulation_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::Surface_mesh_default_criteria_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, false> >, std::pair<CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > > >, CGAL::Default>, false>, int>, CGAL::Null_mesher_level, (CGAL::Surface_mesher::Verbose_flag)0u>; Element = std::pair<CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > > >, CGAL::Default>, false>, int>; Previous = CGAL::Null_mesher_level; Triangulation_traits = CGAL::Triangulation_mesher_level_traits_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >]’
/home/manolivi/local/include/CGAL/Surface_mesher/Surface_mesher.h:735:2:   required from ‘void CGAL::Surface_mesher::Surface_mesher<Base, Element, PreviousLevel, verbose>::init() [with Base = CGAL::Surface_mesher::Surface_mesher_manifold_base<CGAL::Complex_2_in_triangulation_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::Surface_mesh_default_criteria_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, CGAL::Surface_mesher::Surface_mesher_regular_edges_base<CGAL::Complex_2_in_triangulation_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::Surface_mesh_default_criteria_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, false> >; Element = std::pair<CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > > >, CGAL::Default>, false>, int>; PreviousLevel = CGAL::Null_mesher_level; CGAL::Surface_mesher::Verbose_flag verbose = (CGAL::Surface_mesher::Verbose_flag)0u]’
/home/manolivi/local/include/CGAL/Surface_mesher/Surface_mesher.h:748:2:   required from ‘void CGAL::Surface_mesher::Surface_mesher<Base, Element, PreviousLevel, verbose>::refine_mesh(Visitor) [with Visitor = CGAL::Null_mesh_visitor; Base = CGAL::Surface_mesher::Surface_mesher_manifold_base<CGAL::Complex_2_in_triangulation_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::Surface_mesh_default_criteria_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, CGAL::Surface_mesher::Surface_mesher_regular_edges_base<CGAL::Complex_2_in_triangulation_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::Surface_mesh_default_criteria_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, false> >; Element = std::pair<CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > > >, CGAL::Default>, false>, int>; PreviousLevel = CGAL::Null_mesher_level; CGAL::Surface_mesher::Verbose_flag verbose = (CGAL::Surface_mesher::Verbose_flag)0u]’
/home/manolivi/local/include/CGAL/Surface_mesher/Surface_mesher.h:740:7:   required from ‘void CGAL::Surface_mesher::Surface_mesher<Base, Element, PreviousLevel, verbose>::refine_mesh() [with Base = CGAL::Surface_mesher::Surface_mesher_manifold_base<CGAL::Complex_2_in_triangulation_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::Surface_mesh_default_criteria_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, CGAL::Surface_mesher::Surface_mesher_regular_edges_base<CGAL::Complex_2_in_triangulation_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >, CGAL::Surface_mesh_default_criteria_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >, false> >; Element = std::pair<CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > > >, CGAL::Default>, false>, int>; PreviousLevel = CGAL::Null_mesher_level; CGAL::Surface_mesher::Verbose_flag verbose = (CGAL::Surface_mesher::Verbose_flag)0u]’
/home/manolivi/local/include/CGAL/make_surface_mesh.h:101:3:   required from ‘void CGAL::make_surface_mesh(C2T3&, const typename SurfaceMeshTraits_3::Surface_3&, const SurfaceMeshTraits_3&, const Criteria&, Tag, int) [with C2T3 = CGAL::Complex_2_in_triangulation_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >; SurfaceMeshTraits_3 = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >; Criteria = CGAL::Surface_mesh_default_criteria_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >; Tag = CGAL::Manifold_tag; typename SurfaceMeshTraits_3::Surface_3 = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >]’
/home/manolivi/src/openmeegEOlivi/tools/cgal_mesh_create.cpp:117:97:   required from here
/home/manolivi/src/openmeegEOlivi/tools/cgal_mesh_include.h:176:98: erreur: conversion from ‘boost::optional<std::pair<boost::variant<CGAL::Point_3<CGAL::Epick>, CGAL::Segment_3<CGAL::Epick>, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_>, CGAL::internal::In_place_list_const_iterator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>, std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Plane_3<CGAL::Epick> > > >, std::allocator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>, std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Plane_3<CGAL::Epick> > > > > > > >’ to non-scalar type ‘CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >::Intersect_3::AABB_intersection {aka boost::optional<std::pair<CGAL::Object, CGAL::internal::In_place_list_const_iterator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>, std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Plane_3<CGAL::Epick> > > >, std::allocator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>, std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Plane_3<CGAL::Epick> > > > > > > >}’ requested
/home/manolivi/src/openmeegEOlivi/tools/cgal_mesh_include.h: In instantiation of ‘CGAL::Object CGAL::AABB_polyhedral_oracle<Polyhedron, Kernel, Dummy_kernel>::Intersect_3::operator()(const Surface_3&, const Ray_3&) const [with Polyhedron = CGAL::Polyhedron_3<CGAL::Epick>; Kernel = CGAL::Epick; Dummy_kernel = CGAL::Simple_cartesian<double>; CGAL::AABB_polyhedral_oracle<Polyhedron, Kernel, Dummy_kernel>::Surface_3 = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >; CGAL::AABB_polyhedral_oracle<Polyhedron, Kernel, Dummy_kernel>::Ray_3 = CGAL::Ray_3<CGAL::Epick>]’:
/home/manolivi/local/include/CGAL/Surface_mesher/Surface_mesher.h:608:2:   required from ‘bool CGAL::Surface_mesher::Surface_mesher_base<C2T3, Surface_, SurfaceMeshTraits, Criteria_>::is_facet_on_surface(const Facet&, CGAL::Surface_mesher::Surface_mesher_base<C2T3, Surface_, SurfaceMeshTraits, Criteria_>::Point&) [with C2T3 = CGAL::Complex_2_in_triangulation_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >; Surface_ = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >; SurfaceMeshTraits = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >; Criteria_ = CGAL::Surface_mesh_default_criteria_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >; CGAL::Surface_mesher::Surface_mesher_base<C2T3, Surface_, SurfaceMeshTraits, Criteria_>::Facet = std::pair<CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > > >, CGAL::Default>, false>, int>; CGAL::Surface_mesher::Surface_mesher_base<C2T3, Surface_, SurfaceMeshTraits, Criteria_>::Point = CGAL::Point_3<CGAL::Epick>]’
/home/manolivi/src/openmeegEOlivi/tools/cgal_mesh_include.h:186:94: erreur: conversion from ‘boost::optional<std::pair<boost::variant<CGAL::Point_3<CGAL::Epick>, CGAL::Segment_3<CGAL::Epick>, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_>, CGAL::internal::In_place_list_const_iterator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>, std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Plane_3<CGAL::Epick> > > >, std::allocator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>, std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Plane_3<CGAL::Epick> > > > > > > >’ to non-scalar type ‘CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >::Intersect_3::AABB_intersection {aka boost::optional<std::pair<CGAL::Object, CGAL::internal::In_place_list_const_iterator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>, std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Plane_3<CGAL::Epick> > > >, std::allocator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>, std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Plane_3<CGAL::Epick> > > > > > > >}’ requested
/home/manolivi/src/openmeegEOlivi/tools/cgal_mesh_include.h: In instantiation of ‘CGAL::Object CGAL::AABB_polyhedral_oracle<Polyhedron, Kernel, Dummy_kernel>::Intersect_3::operator()(const Surface_3&, const Line_3&) const [with Polyhedron = CGAL::Polyhedron_3<CGAL::Epick>; Kernel = CGAL::Epick; Dummy_kernel = CGAL::Simple_cartesian<double>; CGAL::AABB_polyhedral_oracle<Polyhedron, Kernel, Dummy_kernel>::Surface_3 = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >; CGAL::AABB_polyhedral_oracle<Polyhedron, Kernel, Dummy_kernel>::Line_3 = CGAL::Line_3<CGAL::Epick>]’:
/home/manolivi/local/include/CGAL/Surface_mesher/Surface_mesher.h:612:2:   required from ‘bool CGAL::Surface_mesher::Surface_mesher_base<C2T3, Surface_, SurfaceMeshTraits, Criteria_>::is_facet_on_surface(const Facet&, CGAL::Surface_mesher::Surface_mesher_base<C2T3, Surface_, SurfaceMeshTraits, Criteria_>::Point&) [with C2T3 = CGAL::Complex_2_in_triangulation_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >; Surface_ = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >; SurfaceMeshTraits = CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >; Criteria_ = CGAL::Surface_mesh_default_criteria_3<CGAL::Delaunay_triangulation_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > >, CGAL::Default> >; CGAL::Surface_mesher::Surface_mesher_base<C2T3, Surface_, SurfaceMeshTraits, Criteria_>::Facet = std::pair<CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Epick>, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > > >, CGAL::Default>, false>, int>; CGAL::Surface_mesher::Surface_mesher_base<C2T3, Surface_, SurfaceMeshTraits, Criteria_>::Point = CGAL::Point_3<CGAL::Epick>]’
/home/manolivi/src/openmeegEOlivi/tools/cgal_mesh_include.h:196:95: erreur: conversion from ‘boost::optional<std::pair<boost::variant<CGAL::Point_3<CGAL::Epick>, CGAL::Segment_3<CGAL::Epick>, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_, boost::detail::variant::void_>, CGAL::internal::In_place_list_const_iterator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>, std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Plane_3<CGAL::Epick> > > >, std::allocator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>, std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Plane_3<CGAL::Epick> > > > > > > >’ to non-scalar type ‘CGAL::AABB_polyhedral_oracle<CGAL::Polyhedron_3<CGAL::Epick>, CGAL::Epick, CGAL::Simple_cartesian<double> >::Intersect_3::AABB_intersection {aka boost::optional<std::pair<CGAL::Object, CGAL::internal::In_place_list_const_iterator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>, std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Plane_3<CGAL::Epick> > > >, std::allocator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>, std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Plane_3<CGAL::Epick> > > > > > > >}’ requested
make[2]: *** [tools/CMakeFiles/om_cgal_mesh_create.dir/cgal_mesh_create.cpp.o] Erreur 1
make[1]: *** [tools/CMakeFiles/om_cgal_mesh_create.dir/all] Erreur 2
make: *** [all] Erreur 2
