- To:
- Subject: Re: [cgal-discuss] 4.3 : Triangle_3_Triangle_3 intersection
- Date: Thu, 28 Nov 2013 16:35:10 +0100
I can reproduce it. I investigate and let you know.
Sebastien.
On 11/28/2013 03:13 PM, Hugo Mercier wrote:
Hi,
The behaviour of CGAL::intersection( Triangle_3, Triangle_3 ) changes in
4.3.
With these two triangles :
CGAL::Triangle_3<K> tri1( CGAL::Point_3<K>( 0, 0, 0 ),
CGAL::Point_3<K>( 0, 1, 1 ),
CGAL::Point_3<K>( 0, 1, 0 ) );
CGAL::Triangle_3<K> tri2( CGAL::Point_3<K>( -1, -1, 0 ),
CGAL::Point_3<K>( 0, -1, 0 ),
CGAL::Point_3<K>( -1, 0, 0 ) );
it returns the point (0, -1, 0). Which is wrong, the two triangles do
not intersect.
If I understand Triangle_3_Triangle_3_intersection.h correctly, the
intersection between the two supporting planes is computed (here a line)
and then the intersection of each triangle with this line (here a
segment for tri1 and a point for tri2). Then ... the point is returned.
I think the point should only be returned if it intersects the other
segment (which is not the case here).
Do you reproduce / agree ?
- [cgal-discuss] 4.3 : Triangle_3_Triangle_3 intersection, Hugo Mercier, 11/28/2013
- Re: [cgal-discuss] 4.3 : Triangle_3_Triangle_3 intersection, Sebastien Loriot (GeometryFactory), 11/28/2013
