- To:
- Subject: Re: [cgal-discuss] 4.3 : Triangle_3_Triangle_3 intersection
- Date: Thu, 28 Nov 2013 17:15:58 +0100
Please find attached the patched file CGAL/Triangle_3_Triangle_3_intersection.h
The bug has been introduced when porting the old API to the new one.
Sorry for the regression.
Sebastien.
On 11/28/2013 04:35 PM, Sebastien Loriot (GeometryFactory) wrote:
I can reproduce it. I investigate and let you know.
Sebastien.
On 11/28/2013 03:13 PM, Hugo Mercier wrote:
Hi,
The behaviour of CGAL::intersection( Triangle_3, Triangle_3 ) changes in
4.3.
With these two triangles :
CGAL::Triangle_3<K> tri1( CGAL::Point_3<K>( 0, 0, 0 ),
CGAL::Point_3<K>( 0, 1, 1 ),
CGAL::Point_3<K>( 0, 1, 0 ) );
CGAL::Triangle_3<K> tri2( CGAL::Point_3<K>( -1, -1, 0 ),
CGAL::Point_3<K>( 0, -1, 0 ),
CGAL::Point_3<K>( -1, 0, 0 ) );
it returns the point (0, -1, 0). Which is wrong, the two triangles do
not intersect.
If I understand Triangle_3_Triangle_3_intersection.h correctly, the
intersection between the two supporting planes is computed (here a line)
and then the intersection of each triangle with this line (here a
segment for tri1 and a point for tri2). Then ... the point is returned.
I think the point should only be returned if it intersects the other
segment (which is not the case here).
Do you reproduce / agree ?
// Copyright (c) 2010 GeometryFactory (France). // All rights reserved. // // This file is part of CGAL (www.cgal.org); you can redistribute it and/or // modify it under the terms of the GNU Lesser General Public License as // published by the Free Software Foundation; either version 3 of the License, // or (at your option) any later version. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // $URL$ // $Id$ // // // Author(s) : Sebastien Loriot // #ifndef CGAL_TRIANGLE_3_TRIANGLE_3_INTERSECTION_H #define CGAL_TRIANGLE_3_TRIANGLE_3_INTERSECTION_H #include <CGAL/Intersection_traits_3.h> #include <boost/next_prior.hpp> #include <list> #include <vector> #include <map> namespace CGAL { template <class K> class Triangle_3; namespace internal{ template <class Kernel> void intersection_coplanar_triangles_cutoff( const typename Kernel::Point_3& p, const typename Kernel::Point_3& q, const typename Kernel::Point_3& r, const Kernel& k, std::list<typename Kernel::Point_3>& inter_pts ) { if ( inter_pts.empty() ) return; typedef typename std::list<typename Kernel::Point_3>::iterator Iterator; typename Kernel::Coplanar_orientation_3 orient=k.coplanar_orientation_3_object(); typename Kernel::Construct_line_3 Line_3=k.construct_line_3_object(); //orient(p,q,r,r) is POSITIVE std::map<const typename Kernel::Point_3*,Orientation> orientations; for (Iterator it=inter_pts.begin();it!=inter_pts.end();++it) orientations[ &(*it) ]=orient(p,q,r,*it); int pt_added=0; const typename Kernel::Point_3* prev = &(*boost::prior(inter_pts.end())); Iterator stop = inter_pts.size() > 2 ? inter_pts.end() : boost::prior(inter_pts.end()); for (Iterator it=inter_pts.begin();it!=stop;++it) { const typename Kernel::Point_3& curr=*it; Orientation or_prev=orientations[prev],or_curr=orientations[&curr]; if ( (or_prev==POSITIVE && or_curr==NEGATIVE) || (or_prev==NEGATIVE && or_curr==POSITIVE) ) { typename Intersection_traits<Kernel, typename Kernel::Line_3, typename Kernel::Line_3> ::result_type obj = intersection(Line_3(p,q),Line_3(*prev,curr),k); // assert "not empty" CGAL_kernel_assertion(obj); const typename Kernel::Point_3* inter=intersect_get<typename Kernel::Point_3>(obj); CGAL_kernel_assertion(inter!=NULL); prev=&(* inter_pts.insert(it,*inter) ); orientations[prev]=COLLINEAR; ++pt_added; } prev=&(*it); } CGAL_kernel_assertion(pt_added<3); Iterator it=inter_pts.begin(); while(it!=inter_pts.end()) { if (orientations[&(*it)]==NEGATIVE) inter_pts.erase(it++); else ++it; } } template <class K> typename Intersection_traits<K, typename K::Triangle_3, typename K::Triangle_3>::result_type intersection_coplanar_triangles( const typename K::Triangle_3& t1, const typename K::Triangle_3& t2, const K& k) { const typename K::Point_3& p=t1.vertex(0),q=t1.vertex(1),r=t1.vertex(2); std::list<typename K::Point_3> inter_pts; inter_pts.push_back(t2.vertex(0)); inter_pts.push_back(t2.vertex(1)); inter_pts.push_back(t2.vertex(2)); //intersect t2 with the three half planes which intersection defines t1 intersection_coplanar_triangles_cutoff(p,q,r,k,inter_pts); //line pq intersection_coplanar_triangles_cutoff(q,r,p,k,inter_pts); //line qr intersection_coplanar_triangles_cutoff(r,p,q,k,inter_pts); //line rp switch ( inter_pts.size() ) { case 0: return intersection_return<typename K::Intersect_3, typename K::Triangle_3, typename K::Triangle_3>(); case 1: return intersection_return<typename K::Intersect_3, typename K::Triangle_3, typename K::Triangle_3>( * inter_pts.begin() ); case 2: return intersection_return<typename K::Intersect_3, typename K::Triangle_3, typename K::Triangle_3>( k.construct_segment_3_object()(*inter_pts.begin(), *boost::next(inter_pts.begin())) ); case 3: return intersection_return<typename K::Intersect_3, typename K::Triangle_3, typename K::Triangle_3>( k.construct_triangle_3_object()(*inter_pts.begin(), *boost::next(inter_pts.begin()), *boost::prior(inter_pts.end())) ); default: return intersection_return<typename K::Intersect_3, typename K::Triangle_3, typename K::Triangle_3>( std::vector<typename K::Point_3>(inter_pts.begin(),inter_pts.end()) ); } } template<typename K> struct Triangle_Line_visitor { typedef typename Intersection_traits<K, typename K::Triangle_3, typename K::Triangle_3 > ::result_type result_type; result_type operator()(const typename K::Point_3& p, const typename K::Segment_3& s) const { if ( s.has_on(p) ) return intersection_return<typename K::Intersect_3, typename K::Triangle_3, typename K::Triangle_3>(p); else return result_type(); } result_type operator()(const typename K::Segment_3& s, const typename K::Point_3& p) const { return operator()(p,s); } result_type operator()(const typename K::Point_3& p1, const typename K::Point_3& p2) const { if (p1==p2) return intersection_return<typename K::Intersect_3, typename K::Triangle_3, typename K::Triangle_3>(p1); else return result_type(); } result_type operator()(const typename K::Segment_3& s1, const typename K::Segment_3& s2) const { typename Intersection_traits<K, typename K::Segment_3, typename K::Segment_3>::result_type v = intersection_collinear_segments(s1,s2,K()); if(v) { if(const typename K::Segment_3* s = intersect_get<typename K::Segment_3>(v)) return intersection_return<typename K::Intersect_3, typename K::Triangle_3, typename K::Triangle_3>(*s); if(const typename K::Point_3* p = intersect_get<typename K::Point_3>(v)) return intersection_return<typename K::Intersect_3, typename K::Triangle_3, typename K::Triangle_3>(*p); } return result_type(); } }; template <class K> typename Intersection_traits<K, typename K::Triangle_3, typename K::Triangle_3>::result_type intersection( const typename K::Triangle_3& t1, const typename K::Triangle_3& t2, const K& k) { CGAL_precondition(!t1.is_degenerate() && !t2.is_degenerate()); typename Intersection_traits<K, typename K::Plane_3, typename K::Plane_3>::result_type v = internal::intersection(t1.supporting_plane(), t2.supporting_plane(), k); if(!v) { // empty plane plane intersection return intersection_return<typename K::Intersect_3, typename K::Triangle_3, typename K::Triangle_3>(); } if(intersect_get<typename K::Plane_3>(v)) { //coplanar triangles return intersection_coplanar_triangles(t1,t2,k); } if(const typename K::Line_3* line=intersect_get<typename K::Line_3>(v)) { //The supporting planes of the triangles intersect along a line. typedef typename Intersection_traits<K, typename K::Triangle_3, typename K::Line_3>::result_type Triangle_Line_Inter; Triangle_Line_Inter inter1 = intersection_coplanar(t1,*line,k); Triangle_Line_Inter inter2 = intersection_coplanar(t2,*line,k); if(!inter1 || !inter2) { // one of the intersection is empty return intersection_return<typename K::Intersect_3, typename K::Triangle_3, typename K::Triangle_3>(); } #if CGAL_INTERSECTION_VERSION < 2 // apply the binary visitor manually Triangle_Line_visitor<K> vis; if(const typename K::Point_3* p1 = intersect_get<typename K::Point_3>(inter1)) { if(const typename K::Point_3* p2 = intersect_get<typename K::Point_3>(inter2)) { return vis(*p1, *p2); } else if(const typename K::Segment_3* s2 = intersect_get<typename K::Segment_3>(inter2)) { return vis(*p1, *s2); } } else if(const typename K::Segment_3* s1 = intersect_get<typename K::Segment_3>(inter1)) { if(const typename K::Point_3* p2 = intersect_get<typename K::Point_3>(inter2)) { return vis(*s1, *p2); } else if(const typename K::Segment_3* s2 = intersect_get<typename K::Segment_3>(inter2)) { return vis(*s1, *s2); } } #else return boost::apply_visitor(Triangle_Line_visitor<K>(), *inter1, *inter2); #endif } return intersection_return<typename K::Intersect_3, typename K::Triangle_3, typename K::Triangle_3>(); } }//namespace internal CGAL_INTERSECTION_FUNCTION_SELF(Triangle_3, 3) } // namespace CGAL #endif //CGAL_TRIANGLE_3_TRIANGLE_3_INTERSECTION_H
- [cgal-discuss] 4.3 : Triangle_3_Triangle_3 intersection, Hugo Mercier, 11/28/2013
- Re: [cgal-discuss] 4.3 : Triangle_3_Triangle_3 intersection, Sebastien Loriot (GeometryFactory), 11/28/2013
