Re: [cgal-discuss] Using oriented 3D cuboids as geometric primitives in the AABB tree
- To:
- Subject: Re: [cgal-discuss] Using oriented 3D cuboids as geometric primitives in the AABB tree
- Date: Fri, 13 Dec 2013 07:38:24 +0100
On 12/12/2013 12:04 PM, uschwes wrote:
Hi,
I'm fairly new to CGAL, so the answer might be straight forward:
I am having an application in which I want to perform collision detection
with car-like (rectangular) objects in a dynamic scenario. Basically
checking trajectories of rectangular agents for collision. I was thinking
about constructing an AABB tree in 3D space (x,y,time). Each object in the
scene would create a 3D cuboid at a given point in time.
Note that the objects in the AABB-tree must be static scene must be static.
I have two questions regarding this:
1) Is the AABB tree a good data structure for this, given that the scene
content changes in every computation cycle or is there a better one? As a
rough estimate, I will have about 500-1000 cuboids that I have to insert
into the tree and about 20 times as much collision queries.
2) I was not able to construct the AABB tree with BBox_3 objects so far
because of the missing Do_intersect_3 for these types, I guess. Are these
primitives not supposed to be used within the AABB tree? What would I have
to implement in order to use these?
I guess you wrote your own primitive type, right?
Sebastien.
Thanks a lot for answers,
Ulrich
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Using-oriented-3D-cuboids-as-geometric-primitives-in-the-AABB-tree-tp4658540.html
- [cgal-discuss] Using oriented 3D cuboids as geometric primitives in the AABB tree, uschwes, 12/12/2013
- Re: [cgal-discuss] Using oriented 3D cuboids as geometric primitives in the AABB tree, Sebastien Loriot (GeometryFactory), 12/13/2013
- Re: [cgal-discuss] Using oriented 3D cuboids as geometric primitives in the AABB tree, uschwes, 12/18/2013
- Re: [cgal-discuss] Using oriented 3D cuboids as geometric primitives in the AABB tree, Sebastien Loriot (GeometryFactory), 12/19/2013
