Re: [cgal-discuss] Using oriented 3D cuboids as geometric primitives in the AABB tree
- To:
- Subject: Re: [cgal-discuss] Using oriented 3D cuboids as geometric primitives in the AABB tree
- Date: Thu, 19 Dec 2013 07:02:43 +0100
On 12/18/2013 11:53 PM, uschwes wrote:
I guess you wrote your own primitive type, right?
That´s basically my question :-). Do I have to do that?
So far I tried to use the CGAL::BBox_3 object inside the AABB tree. I
thought it would be possible to use that primitive directly, no?
You have to write a primitive wrapper model of http://doc.cgal.org/latest/AABB_tree/classAABBPrimitive.html
You can use the following one
http://doc.cgal.org/latest/AABB_tree/structCGAL_1_1AABB__primitive.html
and you'll only need to write property maps.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Using-oriented-3D-cuboids-as-geometric-primitives-in-the-AABB-tree-tp4658540p4658569.html
- [cgal-discuss] Using oriented 3D cuboids as geometric primitives in the AABB tree, uschwes, 12/12/2013
- Re: [cgal-discuss] Using oriented 3D cuboids as geometric primitives in the AABB tree, Sebastien Loriot (GeometryFactory), 12/13/2013
- Re: [cgal-discuss] Using oriented 3D cuboids as geometric primitives in the AABB tree, uschwes, 12/18/2013
- Re: [cgal-discuss] Using oriented 3D cuboids as geometric primitives in the AABB tree, Sebastien Loriot (GeometryFactory), 12/19/2013
