cgal-discuss - Re: [cgal-discuss] Bug in Inventor_ostream.h and VRML_2_ostream.h
  • To: , Philipp Moeller <>
  • Subject: Re: [cgal-discuss] Bug in Inventor_ostream.h and VRML_2_ostream.h
  • Date: Sun, 15 Dec 2013 10:53:40 +0900
Thank you so much for your help.
Could you provide a the error output? I believe
this could be related to returning `const void*` instead of
`void*`. There has been a clang bug that rejected an overload when
const-ness has been involved.
No problem. Sorry that I have not included the error output in the report.
Or more specifically, the following command reproduces the problem
I simplified the command, but it does essentially the same thing as the old one. (I just moved the source files to my user directory.)
$ /usr/bin/clang++ -DCGAL_USE_GMP -DCGAL_USE_MPFR -pipe -Os -I/opt/local/include -arch x86_64 -arch i386  -DNDEBUG -arch x86_64 -arch i386 -ICGAL-4.3/include -isystem /opt/local/include -ICGAL-4.3/examples/Polyhedron_IO -o off2iv.cpp.o -c CGAL-4.3/examples/Polyhedron_IO/off2iv.cpp
The output:
In file included from CGAL-4.3/examples/Polyhedron_IO/off2iv.cpp:4:
CGAL-4.3/include/CGAL/IO/Inventor_ostream.h:57:20: error: no viable conversion
      from 'std::ostream' (aka 'basic_ostream<char>') to 'Const_void_ptr'
      (aka 'const void *')
            return *m_os;
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/c++/v1/ios:576:9: note:
      candidate function
        operator bool() const {return !fail();}
1 error generated.
Sincerely,
Daisuke
Philipp Moeller wrote:
Daisuke Sakurai <> writes:
I have found a possible bug in "Inventor_ostream.h" and "VRML_2_ostream.h".
I believe that the attached patches fix the problem.
Problem: some examples, which ship with CGAL 4.3, fail to compile.
Each of the examples include at least one of the two .h files.
In order to reproduce the bug for "Inventor_ostream.h", I simply need
to compile the example,
Thanks for the patches, but I don't think they are right. After your
patches a non-null pointer will be returned even if the underlying
stream failed, which is clearly not what should happen.
I currently don't have access to Mac OS X 10.9 and the Apple clang, so I
cannot confirm this. Could you provide a the error output? I believe
The compilations fail for the clang++ compiler, at least on my Mac OS
X 10.9.
To avoid the errors, I applied the following patches:
--- CGAL-4.3/include/CGAL/IO/Inventor_ostream.h.orig    2013-12-13
18:03:44.000000000 +0900
+++ CGAL-4.3/include/CGAL/IO/Inventor_ostream.h    2013-12-13
18:04:17.000000000 +0900
@@ -54,7 +54,7 @@
     typedef const void* Const_void_ptr;
     operator Const_void_ptr () const {
         if ( m_os)
-            return *m_os;
+            return m_os;
         return 0;
     #else
--- CGAL-4.3/include/CGAL/IO/VRML_2_ostream.h.orig    2013-12-13
18:30:39.000000000 +0900
+++ CGAL-4.3/include/CGAL/IO/VRML_2_ostream.h    2013-12-13
18:30:52.000000000 +0900
@@ -48,7 +48,7 @@
         if ( m_os)
-            return *m_os;
+            return m_os;
         return 0;
     #else
It seems that removing the asterisks makes the compilation continue.
However, I am not sure if this is the correct solution to the problem.
I attach the patches to this email.
Additional info:
which operating system, compiler, and hardware you are using:
Mac OS X 10.9
/usr/bin/clang++
Apple LLVM version 5.0 (clang-500.2.79) (based on LLVM 3.3svn)
Target: x86_64-apple-darwin13.0.0
Thread model: posix
Intel Core i7
information about how CGAL was installed on your system (i.e., which
options were used, how the library was built, etc.):
I used macports.
$ sudo port install cgal +demos +qt4 +universal
a description of the problem or bug and a way to reproduce it (such as
a small sample program or a sequence of commands):
Again,
(after the above command "port install cgal +demos +qt4 +universal"
leaves failing source codes).
$ sudo /usr/bin/clang++ -DCGAL_USE_GMP -DCGAL_USE_MPFR -pipe -Os
-arch i386
-I/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_gis_cgal/cgal/work/CGAL-4.3/examples/Polyhedron_IO/../../include
-I/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_gis_cgal/cgal/work/CGAL-4.3/include
-o CMakeFiles/off2iv.dir/off2iv.cpp.o -c
/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_gis_cgal/cgal/work/CGAL-4.3/examples/Polyhedron_IO/off2iv.cpp
Daisuke Sakurai
