Re: [cgal-discuss] Assertion converting Polyhedron_3 to Nef_polyhedron_3 / Nef_polyhedron VERY slow with extended kernel
- To:
- Subject: Re: [cgal-discuss] Assertion converting Polyhedron_3 to Nef_polyhedron_3 / Nef_polyhedron VERY slow with extended kernel
- Date: Sun, 15 Dec 2013 13:30:51 -0500
On Sep 27, 2013, at 10:58 AM, Andre Schmeisser
wrote:
>> The following is working:
>> istringstream off(polyhedronOffStr);
>> Nef_polyhedron NP;
>> CGAL::OFF_to_nef_3(off, NP);
> Thanks, this works.
> Is there a way to directly construct the Nef polyhedron without first
> serializing to/from an OFF string?
Hi Andre,
Did you ever figure this out?
I have a very similar issue..
It looks like the OFF_to_nef_3() function manually projects all polygons into
a 2D plane, performs a constrained triangulation before constructing the Nef
from the triangles. Since this functionality is not specific to OFF files, it
would make sense to have a more robust builder which could construct Nef
polyhedrons from polygon meshes, including Polyhedron_3.
Kind Regards,
-Marius
- Re: [cgal-discuss] Assertion converting Polyhedron_3 to Nef_polyhedron_3 / Nef_polyhedron VERY slow with extended kernel, Marius Kintel, 12/15/2013
