- To:
- Subject: Re: [cgal-discuss] do_intersect for pairs of tetrahedrons?
- Date: Tue, 7 Jan 2014 07:31:55 -0800 (PST)
Hi Amy,
Has something changed on this topic during the last four years? Is there a
do_intersect function for tetrahedra in CGAL now?
Best regards, Mikhail Matrosov
Amy Tabb wrote
> Hi Andre,
> Okay, I had responded to the second part about computing the actual
> intersection, which you knew about, but not the first part, about
> detecting the intersection.
> The equivalent of the CGAL `do_intersect' function in 3D is what is
> usually called the `intersection detection' or `intersection
> counting/reporting' problem. There has been a lot of work done on this,
> with different strategies depending on the complexity of the objects
> involved. Luckily, the portion of the Handbook of Discrete and
> Computational Geometry (a pretty expensive and heavy book) that talks
> about this subject is provided online:
> http://www.cs.umd.edu/~mount/Papers/crc-intersect.pdf. Briefly, there
> are two options described there. The bounding box preprocessing option
> associates a bounding box with every polyhedron (or triangle in the
> mesh); the bounding boxes are first tested for intersection before more
> complicated intersection tests on the actual objects within the bounding
> boxes. CGAL provides such a scheme in this package:
> http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Box_intersection_d/Chapter_main.html
> There's an example program that I think might be applicable to your
> problem, in section 51.5 of the above web page.
> The other option is to detect the intersection of convex polyhedra via a
> Dobkin-Kirkpatrick decomposition; this is a more complicated option.
> Good luck.
> Best
> Amy
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/do-intersect-for-pairs-of-tetrahedrons-tp953018p4658615.html
- Re: [cgal-discuss] do_intersect for pairs of tetrahedrons?, mikhail.matrosov, 01/07/2014
