cgal-discuss - Re: [cgal-discuss] Bug in Mesh Decimation?
  • To:
  • Subject: Re: [cgal-discuss] Bug in Mesh Decimation?
  • Date: Tue, 07 Jan 2014 10:24:18 +0100
Hello,
I don't have time right now to look in deep at your problem but it
might be related to a pb already identified for which I provided a
temporary fix over CGAL 4.3 in the following thread:
http://cgal-discuss.949826.n4.nabble.com/Mesh-simplification-with-edges-marked-as-non-removable-td4658180.html
Could you have a look and tell me if that is the same issue or not?
(note that the placement in the cpp file is also important, not only
the patched CGAL header)
Thanks,
Sebastien.
On 01/04/2014 12:17 AM, jccosta wrote:
Hi,
I am trying to use the CGAL decimation algorithms to simplify some meshes.
After I tested the algorithms on some meshes I've got, I am getting some
really weird results (new vertexes are being placed in bad positions)
besides the boundary edges not being preserved even though they have been
included in a constraint map.
I am not used to use CGAL, so maybe I am doing some kind of simple mistake.
In order to allow you guys to be able to analyze and test the results that
I've got, I am including the source code for a simple application and the
original mesh to be decimated.
The code was compiled in MacOSX and Linux (there are a Makefile included),
but it should be easy to port for Windows. Please, don't forget to adapt the
Makefile for your system environment.
After compiled, it can be used as: ./decimate test_mesh2.off
test_decimated2.off
Before decimation:
<http://cgal-discuss.949826.n4.nabble.com/file/n4658610/Screen_Shot_2014-01-03_at_6.14.19_PM.png>
Aftter decimation:
<http://cgal-discuss.949826.n4.nabble.com/file/n4658610/Screen_Shot_2014-01-03_at_6.14.06_PM.png>
Thanks!
Source: MeshDecimation.tar.gz
<http://cgal-discuss.949826.n4.nabble.com/file/n4658610/MeshDecimation.tar.gz>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-in-Mesh-Decimation-tp4658610.html
