- To:
- Subject: [cgal-discuss] Point Location in Regular Triangulation
- Date: Mon, 13 Jan 2014 03:23:52 -0800 (PST)
Hello,
I need to check whether the orthogonal center of a cell in Regular
Triangulation (RT) is inside that cell or other cells of RT. I can find the
orthogonal center easily using
RegularTriangulationTraits_3::Construct_weighted_circumcenter_3 .
However, I cannot check the location of this point in RT cells since the
point location functions are defined for Triangulation_3 and
Delaunay_triangulation_3.
Obviously, those functions are designed for bare points not weighted points
and I will lose the correct triangulation if I use them.
I am looking forward to hearing from you
Negin
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Point-Location-in-Regular-Triangulation-tp4658637.html
- [cgal-discuss] Point Location in Regular Triangulation, NeginF, 01/13/2014
- Re: [cgal-discuss] Point Location in Regular Triangulation, Monique Teillaud, 01/13/2014
- Re: [cgal-discuss] Point Location in Regular Triangulation, NeginF, 01/17/2014
