cgal-discuss - Re: [cgal-discuss] Point Location in Regular Triangulation
  • To:
  • Subject: Re: [cgal-discuss] Point Location in Regular Triangulation
  • Date: Mon, 13 Jan 2014 14:49:46 +0100
Hi,
I don't fully understand your problem, how can you lose the triangulation?
locate() is a member function of Triangulation_3.
Both Delaunay_triangulation_3 and Regular_triangulation_3 inherit from Triangulation_3, so, you can locate the bare point stored in the weighted circumcenter using locate().
Monique Teillaud
http://www.inria.fr/sophia/members/Monique.Teillaud/
INRIA Sophia Antipolis - Méditerranée
Institut National de Recherche en Informatique et Automatique
Le 13/01/14 12:23, NeginF a écrit :
Hello,
I need to check whether the orthogonal center of a cell in Regular
Triangulation (RT) is inside that cell or other cells of RT. I can find the
orthogonal center easily using
RegularTriangulationTraits_3::Construct_weighted_circumcenter_3 .
However, I cannot check the location of this point in RT cells since the
point location functions are defined for Triangulation_3 and
Delaunay_triangulation_3.
Obviously, those functions are designed for bare points not weighted points
and I will lose the correct triangulation if I use them.
I am looking forward to hearing from you
Negin
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Point-Location-in-Regular-Triangulation-tp4658637.html
