- To:
- Subject: Re: [cgal-discuss] Error in compiling example code after some modification
- Date: Wed, 15 Jan 2014 06:04:35 +0100
The Lindstrom_Turk placement is using a square root so it does not compile.
I think you can try the midpoint placement which should not have the problem. If you really want to use the default placement, here is a hack:
--- a/CGAL/Surface_mesh_simplification/Policies/Edge_collapse/Detail/Lindstrom_Turk_core_impl.h
+++ b/CGAL/Surface_mesh_simplification/Policies/Edge_collapse/Detail/Lindstrom_Turk_core_impl.h
@@ -419,7 +419,7 @@ void LindstromTurkCore<ECM,K>::Add_constraint_if_alpha_compatible( Vector const&
if ( is_finite(slai) )
- FT l = CGAL_NTS sqrt( slai ) ;
+ FT l = CGAL_NTS sqrt( to_double(slai) ) ;
Note that I do not recommend to use this algorithm using this kernel.
Sebastien.
On 01/14/2014 11:31 AM, tang wrote:
Dear all,
I am trying to do some modification to the example code:
http://doc.cgal.org/latest/Surface_mesh_simplification/Surface_mesh_simplification_2edge_collapse_constrained_polyhedron_8cpp-example.html
I try to change the Kernel from
CGAL::Simple_cartesian<double>
to
CGAL::Exact_predicates_exact_constructions_kernel
As a result, I have the following modification in the example code:
1) line 4, changed
#include <CGAL/Simple_cartesian.h>
to
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
2) line 20, changed
typedef CGAL::Simple_cartesian<double> Kernel;
to
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
However, after modification, the following errors displayed:
error C2440: 'initializing' : cannot convert from
'CGAL::Null_functor::result_type' to 'CGAL::Lazy_exact_nt<ET_>'
Could anyone tell me how to modify the code to let it pass the compling and
building?
Thanks
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Error-in-compiling-example-code-after-some-modification-tp4658641.html
- [cgal-discuss] Error in compiling example code after some modification, tang, 01/14/2014
- Re: [cgal-discuss] Error in compiling example code after some modification, Sebastien Loriot (GeometryFactory), 01/15/2014
