- To:
- Subject: Re: [cgal-discuss] Error in compiling example code after some modification
- Date: Thu, 16 Jan 2014 05:41:42 -0800 (PST)
Hi Sebastien,
Thank you very much for your kindly reply. However, I simplified the surface
meshes by removing short edges one by one. I suggest that latter version let
the simplification operations be easier to be used.
Thanks.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Error-in-compiling-example-code-after-some-modification-tp4658641p4658659.html
- [cgal-discuss] Error in compiling example code after some modification, tang, 01/14/2014
- Re: [cgal-discuss] Error in compiling example code after some modification, Sebastien Loriot (GeometryFactory), 01/15/2014
- Re: [cgal-discuss] Error in compiling example code after some modification, tang, 01/16/2014
