Re: [cgal-discuss] 4.3: some Arrangement2 methods in documentation, but missing in source?
- To:
- Subject: Re: [cgal-discuss] 4.3: some Arrangement2 methods in documentation, but missing in source?
- Date: Thu, 16 Jan 2014 12:37:53 +0200
Hi FritzM,
It seems that you are correct.1. The missing method
Arr_linear_traits_2::Curve_2::Curve_2 (const Point_2 &p)
insert(arr, curve) or even better insert_non_intersecting_curve(arr, curve); if not, let me know. However, at first glance, they might be useful (as they should be more efficient to use when appropriate), so I may add them as well.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On Thu, Jan 16, 2014 at 8:26 AM, Fritz Mueller <> wrote:
Hi,
I've noticed a few Arrangement2 related routines mentioned in the current
4.3 HTML docs that I (and the linker) have been unable to track down in the
sources. A few examples are:
Halfedge_handle Arrangement_2::insert_in_face_interior (const
X_monotone_curve_2 &c, Halfedge_handle fict_pred1, Halfedge_handle
fict_pred2=Halfedge_handle())
...and some methods missing for insert_from_left_vertex and
insert_from_right_vertex as well.
In all cases so far, I've had now trouble working around this, but just
wanted to point out what might be an inconsistency in the documentation in
case it helps for the next release?
thanks much,
--FritzM.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/4-3-some-Arrangement2-methods-in-documentation-but-missing-in-source-tp4658657.html
- [cgal-discuss] 4.3: some Arrangement2 methods in documentation, but missing in source?, Fritz Mueller, 01/16/2014
- Re: [cgal-discuss] 4.3: some Arrangement2 methods in documentation, but missing in source?, Efi Fogel, 01/16/2014
- Re: [cgal-discuss] 4.3: some Arrangement2 methods in documentation, but missing in source?, Fritz Mueller, 01/16/2014
- Re: [cgal-discuss] 4.3: some Arrangement2 methods in documentation, but missing in source?, Philipp Moeller, 01/16/2014
