- To:
- Subject: Re: [cgal-discuss] Extensible Kernel deeper information
- Date: Wed, 22 Jan 2014 11:43:28 +0100
On 01/20/2014 11:25 PM, Alessandro Attanasi wrote:
Hi all,
I'm going to learn how to plug user defined class into existing CGAL
kernels.
I read all the documentation
http://doc.cgal.org/latest/Kernel_23/index.html#sectionextensiblekernel
and I copy all the example codes concerning the MyPointC2 class into the
manual to run them. At the beginning I was not able to compile because
it needs the MySegmentC2.h file that I didn't find into the manual, so I
comment out everything about it.
I'm writing to better understand this procedure, for example how to
change the code in order to have coordinates of MyPoint to be generic
(using template??), to have more info about MyKernel.h that into the
documentation is explicitly said to not explain details, how predefined
Kernels as EPIC could be used?
As last point I don't understand the sentence
"As we enforce type equality between |MyKernel::Point_2| and |Point_2
<http://doc.cgal.org/latest/Kernel_23/classCGAL_1_1Point__2.html><MyKernel>|,
the constructor with the color as third argument is not available."
because I tried to create with the example code a point having into the
consructor the color too, an it works.
It means that the constructor will not be available if you use Point_2<Kernel>(x,y,color) of Kernel::Point_2 directly. Of course
if you use your point type directly it will work.
Be careful that if you color is an integer for example,
Kernel::Point_2(x,y,color) will call the constructor using homogeneous
coordinates and not the one you expect.
Sebastien.
Thanks
Alessandro
- [cgal-discuss] Extensible Kernel deeper information, Alessandro Attanasi, 01/20/2014
- Re: [cgal-discuss] Extensible Kernel deeper information, Sebastien Loriot (GeometryFactory), 01/22/2014
