cgal-discuss - [cgal-discuss] compilation error with jet_smooth_point
  • To:
  • Subject: [cgal-discuss] compilation error with jet_smooth_point
  • Date: Wed, 22 Jan 2014 13:23:57 +0100
Hi all,
I use debian testing packages for debian (i.e. 4.2.5), and I get an obvious
compilation error when using jet_smooth_point.
Indeed if CGAL_EIGEN3_ENABLED and CGAL_LACPACK_ENABLED are not defined,
Monge_via_jet_fitting requires 3 template arguments (there are no default
template arguments for LocalKernel and for SvdTraits), and in
jet_smooth_point only 1 template parameter is provided for Monge_jet_fitting…
Has the code been fixed in latest release (4.2.3) ?
Thanks,
Arnaud
