- To: "" <>
- Subject: RE: [cgal-discuss] non convex mesh
- Date: Wed, 22 Jan 2014 14:23:30 +0100
- Importance: Normal
Thanks for your answer. It maybe what i need. However doesn't seems to work. I dont know maybe it's a bug.
I tried to use the make_mesh_3, but its not doing what it have to.
I copied the Mesh_3/mesh_implicit_sphere.cpp sample code, it compiled and runned succsessfully, however the generated mesh(or mesh file) is not valid at all. I tried to open it with gmsh, or convert it with tetgen to off, but none of them works. Tetgen finds a lot of trouble in the mesh.
Date: Tue, 21 Jan 2014 13:24:19 +0100
To:
Subject: Re: [cgal-discuss] non convex mesh
Have a look to the 3D mesh generation package.
The functions make_mesh_3 and refine_mesh_3
can be tuned to remesh a triangulated surface
and mesh the interior of this surface.
Note that the gemetry of the input surface will be preserved
but not the representing mesh: the input surface will be retriangulated.
To:
Le 17/01/14 15:13, Jánosi Zoli a
écrit :
Hi, i hope somebody can give me some advice.I have a non convex surface what i want to triangulate in 3d.I have the 3d points of the surface and the surface triangles.Im able to use the triangulation with the points but i get a convex hull.In basic what do i have to use to triangulate this object in 3d with respecting the boundaries. How do i add the surface to the triangulation? Is there any option to achive this in cgal?
-- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis
- [cgal-discuss] non convex mesh, Jánosi Zoli, 01/17/2014
- Re: [cgal-discuss] non convex mesh, Mariette Yvinec, 01/21/2014
- RE: [cgal-discuss] non convex mesh, Jánosi Zoli, 01/22/2014
- Re: [cgal-discuss] non convex mesh, Laurent Rineau (CGAL/GeometryFactory), 01/22/2014
