- To:
- Subject: Re: [cgal-discuss] compilation error with jet_smooth_point
- Date: Wed, 22 Jan 2014 14:16:10 +0100
#include <CGAL/jet_smooth_point_set.h>
void main()
If you just try to compile this example in the case where CGAL_EIGEN3_ENABLED
and CGAL_LAPACK_ENABLED, it won't compileā¦
Cause Monge_via_jet_fitting expect 3 template parameters but the typedef in
jet_smooth_point_set only provides one.
It seems to me that it has only been tested with eigen3, or lapack (?)
On Jan 22, 2014, at 1:57 PM, "Sebastien Loriot (GeometryFactory)"
wrote:
> Can you show a minimal example showing the pb?
> When those macros are defined, it activates some defaults for some
> template parameter. If they are not, then you need to specify
> them by end.
> Sebastien.
> On 01/22/2014 01:23 PM, Arnaud Gelas wrote:
>> Hi all,
>> I use debian testing packages for debian (i.e. 4.2.5), and I get an
>> obvious compilation error when using jet_smooth_point.
>> Indeed if CGAL_EIGEN3_ENABLED and CGAL_LACPACK_ENABLED are not defined,
>> Monge_via_jet_fitting requires 3 template arguments (there are no default
>> template arguments for LocalKernel and for SvdTraits), and in
>> jet_smooth_point only 1 template parameter is provided for
>> Monge_jet_fittingā¦
>> Has the code been fixed in latest release (4.2.3) ?
>> Thanks,
>> Arnaud
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] compilation error with jet_smooth_point, Arnaud Gelas, 01/22/2014
- Re: [cgal-discuss] compilation error with jet_smooth_point, Sebastien Loriot (GeometryFactory), 01/22/2014
- Re: [cgal-discuss] compilation error with jet_smooth_point, Arnaud Gelas, 01/22/2014
- Re: [cgal-discuss] compilation error with jet_smooth_point, Sebastien Loriot (GeometryFactory), 01/23/2014
- Re: [cgal-discuss] compilation error with jet_smooth_point, Arnaud Gelas, 01/23/2014
