cgal-discuss - Re: [cgal-discuss] Bug in Polyhedron_incremental_builder_3::test_facet_indices()
  • To:
  • Subject: Re: [cgal-discuss] Bug in Polyhedron_incremental_builder_3::test_facet_indices()
  • Date: Fri, 24 Jan 2014 07:55:59 +0100
On 01/23/2014 06:50 PM, Marius Kintel wrote:
On Jan 23, 2014, at 03:01 AM, Sebastien Loriot (GeometryFactory)
wrote:
By curiosity how did you find the bug because the manifold edge test
coming after is failing on the tests I did.
For my test, the manifold edge test passes (the first if statement is never
true). I didn’t look deeper into that code.
I don’t know a good way of feeding my data to CGAL, but the attached OFF file
describes my situation.
I’m basically iterating over the faces and feeding it to a
Polyhedron_incremental_builder_3.
The fifth index should fail but doesn’t.
Once I add the broken triangle, I get a Precondition Error if trying to add
the next face, which makes sense.
Ah! I see. Thanks for the answer.
Sebastien.
-Marius
