- To:
- Subject: Re: [cgal-discuss] Bug of 'join_vertex' in CGAL?
- Date: Fri, 24 Jan 2014 14:36:02 +0100
Note that this might not work if you use it on a surface with boundaries.
Sebastien.
On 01/16/2014 02:48 PM, tang wrote:
Hi Sebastien,
Thank you very much for your kindly reply. I test the function
'halfedge_collapse' to remove short edges, however, it crashed. Finally I
solved this problem by adopting the function 'remove_short_edges' from here:
http://fenicsproject.org/pub/archive/fenics-bzr-to-git-conversion-2013/repositories/bzr/dolfin.bzr/dolfin/generation/PolyhedronUtils.cpp
Thanks.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-of-join-vertex-in-CGAL-tp4658645p4658660.html
- [cgal-discuss] Bug of 'join_vertex' in CGAL?, tang, 01/15/2014
- Re: [cgal-discuss] Bug of 'join_vertex' in CGAL?, Sebastien Loriot (GeometryFactory), 01/15/2014
- Re: [cgal-discuss] Bug of 'join_vertex' in CGAL?, tang, 01/16/2014
- Re: [cgal-discuss] Bug of 'join_vertex' in CGAL?, Sebastien Loriot (GeometryFactory), 01/24/2014
- Re: [cgal-discuss] Bug of 'join_vertex' in CGAL?, tang, 01/26/2014
- Re: [cgal-discuss] Bug of 'join_vertex' in CGAL?, Sebastien Loriot (GeometryFactory), 01/27/2014
