Re: [cgal-discuss] Errors on running make command for installation and tips to compile a sample CGAL program given on the website
- To:
- Subject: Re: [cgal-discuss] Errors on running make command for installation and tips to compile a sample CGAL program given on the website
- Date: Mon, 27 Jan 2014 23:27:44 +0530
Thanks Sebastien ..make worked perfectly after
rm CMakeChache.txt
make
KAVISH DWIVEDI
B.Tech (VII Sem)
INFORMATION TECHNOLOGY
MNNIT , Allahabad
On Mon, Jan 27, 2014 at 11:03 PM, Sebastien Loriot (GeometryFactory)
wrote:
> It seems there is an issue with Qt3.
> Could you try update your CMakeCache.txt and set WITH_CGAL_Qt3 to OFF
> Sebastien.
> On 01/27/2014 12:02 PM, kavish dwivedi wrote:
>> Hi,
>> I am a beginner and trying to get accustomed with CGAL . I installed
>> all the dependencies and then ran cmake . command and make command but
>> the following error is shown http://pastebin.com/jHkUmXPZ . Also I
>> tried to compile the sample C++ program on the CGAL website using g++
>> but it also gave a lot of errors . How should I proceed ?
>> KAVISH DWIVEDI
>> B.Tech (VIII Sem)
>> MNNIT , Allahabad
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Errors on running make command for installation and tips to compile a sample CGAL program given on the website, kavish dwivedi, 01/27/2014
- Re: [cgal-discuss] Errors on running make command for installation and tips to compile a sample CGAL program given on the website, Sebastien Loriot (GeometryFactory), 01/27/2014
- Re: [cgal-discuss] Errors on running make command for installation and tips to compile a sample CGAL program given on the website, kavish dwivedi, 01/27/2014
