Re: [cgal-discuss] incrementally adding new vertices to an existing tetrahedral mesh
- To:
- Cc: "" <>
- Subject: Re: [cgal-discuss] incrementally adding new vertices to an existing tetrahedral mesh
- Date: Mon, 27 Jan 2014 16:07:34 -0500
On 01/27/2014 12:50 PM, Sebastien Loriot (GeometryFactory) wrote:
It is not guarantee that the convex hull of the original mesh will be
preserved in a Delaunay or Regular triangulation after adding the
new nodes. I don't see an easy solution to this problem without using
a conforming triangulation (and even with, you might get some Steiner
points on your constrained facets).
what if we do not require the mesh with the newly added nodes
is Delaunay? we only want to connect the new nodes with the
existing mesh surface in all possible directions without adding
any additional nodes. Is there a technique for this?
Qianqian
Sebastien.
On 01/27/2014 06:13 PM, Qianqian Fang wrote:
On 01/27/2014 02:00 AM, Sebastien Loriot (GeometryFactory) wrote:
Could you give some details on the distribution of new nodes
and how you would like them to be connected to the surface?
hi Sabastien
for a convex shaped mesh, my goal is actually make a new
convex hull including the new nodes, and fill the extended
space with new (delaunay) tetrahedra (the original mesh
space is not changed).
An example is to add a node over the top facet of a cube-like mesh:
the resulting mesh will be a pyramid-over-cube (see attachment):
the bottom cube is the same as the original, the top pyramid is
filled by tetrahedra, each has a base on one of the surface triangles
on the top cube surface, and a tip at the newly added node. If two
nodes are added over the top facet, I expect to see a
"tent-over-cube" mesh, etc ...
For a mesh with cavities, I'd like to again get the convex hull
covering both the old nodes and the new nodes first, and tessellate
the extended space (without refining for quality purposes), and
then remove the new elements that do not share the newly
inserted nodes.
let me know if I can explain this better.
Qianqian
I don't think you will be able to do something like this using
something out-of-the-box.
Sebastien.
On 01/27/2014 12:29 AM, Qianqian Fang wrote:
Dear list:
for a project of mine, I need to modify a pre-made
tetrahedral mesh (output of CGAL 3D mesh generator)
by adding a bunch of additional 3D nodes. The new nodes
are outside of the existing mesh. I'd like to insert new
tetrahedra between the new nodes and the surface triangles
that have direct sight to the new nodes. It is important not
to insert any additional nodes aside from the ones I need.
The quality of the new elements are not important
and thus a quality-based refinement is not preferred.
I am wondering if anyone know if this is possible in
CGAL? it would be wonderful if you can point me to
the CGAL sample or share a code snippet to illustrate
how to implement.
thank you very much
Qianqian
- [cgal-discuss] incrementally adding new vertices to an existing tetrahedral mesh, Qianqian Fang, 01/27/2014
- Re: [cgal-discuss] incrementally adding new vertices to an existing tetrahedral mesh, Sebastien Loriot (GeometryFactory), 01/27/2014
- Re: [cgal-discuss] incrementally adding new vertices to an existing tetrahedral mesh, Qianqian Fang, 01/27/2014
