cgal-discuss - Re: [cgal-discuss] Bug in Mesh Decimation?
  • To:
  • Subject: Re: [cgal-discuss] Bug in Mesh Decimation?
  • Date: Wed, 29 Jan 2014 19:54:47 +0100
Hi Jonathas,
I think I'm almost done with the patch (at least it worked on your file and the testsuite of the package is OK).
I modified a bit the API to make it more clean and there
is a dedicated parameter for passing the constrained edge map.
I join the patched files and an example
(I advice you to use the include_directories(BEFORE XXX) command of cmake to avoid patching your CGAL copy).
Please let me know if it works now for you and whether you find
another issue.
Thanks,
Sebastien.
On 01/15/2014 03:41 PM, jccosta wrote:
Hi Sebastien,
Did you have time to look into this?
Your correction for the vertexes placement works fine, but the patch that
corrects the boundary edges preservation is causing CGAL to break with some
meshes as entries.
Thank you.
Jonathas.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-in-Mesh-Decimation-tp4658610p4658649.html
Attachment: patch.tgz
Description: application/compressed-tar
