- To:
- Subject: Re: [cgal-discuss] Performance issues regarding Delaunay_3 & priority queue
- Date: Sun, 02 Feb 2014 18:40:16 +0100
Hi,
You are using a lot of geometric computations (circumcenter, squared length...). This is quite expensive.
Especially since you are probably computing each circumcenter several times...
Monique Teillaud
http://www.inria.fr/sophia/members/Monique.Teillaud/
INRIA Sophia Antipolis - Méditerranée
Institut National de Recherche en Informatique et Automatique
Le 02/02/14 12:52, jiju peethambaran a écrit :
Hi,
I use a priority queue for ordering the boundary tetrahedra in Delaunay
triangulation_3 for further operations. But after the priority queue
construction, while doing the subsequent operations , the program found to
show very poor performance. In fact, for a point set of size 25000, it took
around 12-13 hours on a system with 32GB RAM and 2.3Ghz processor. My
declaration of priority queue is as follows:
struct Comparator
bool operator()(const Cell_handle lhs, const Cell_handle rhs)
K::FT l1=FT();
K::FT l2=FT();
Tetrahedron_3 tetrahedron1=Tetrahedron_3(lhs->vertex(0)->point(),
lhs->vertex(1)->point(),lhs->vertex(2)->point(),lhs->vertex(3)->point());
Point_3 cc1=CGAL::circumcenter(tetrahedron1);
Segment_3 s1=Segment_3(cc1,lhs->vertex(0)->point());
Tetrahedron_3 tetrahedron2=Tetrahedron_3(rhs->vertex(0)->point(),
rhs->vertex(1)->point(),rhs->vertex(2)->point(),rhs->vertex(3)->point());
Point_3 cc2=CGAL::circumcenter(tetrahedron2);
Segment_3 s2=Segment_3(cc2,rhs->vertex(0)->point());
return s1.squared_length()<s2.squared_length();
priority_queue<Cell_handle, vector<Cell_handle>, Comparator> pq;
In the while loop, apart from 1 pop(), 3 push() (maximum), I use a
Cell_circulator for 3 edges of each tetrahedra that is being popped and a
predicate that use a Cell_iterator that iterates through the incident cells
of a vertex of the tetrahedron being popped. I came to know that, it takes
log(pqsize) for pushing and popping elements to and from the priority queue.
If that is the case, these operations may not be the major contributors to
the overall time. So is it the other two predicates, along with the number
of iteration which are degrading the performance of the algorithm?
In struct comparator, I declare tetrahedron_3, Point_3, Segment_3 etc.. each
time? Will this be a overhead especially in the case of circumcenter
computation in each iteration, if so, is there any viable alternative for
this?
Any suggestions, comments are highly appreciated and valued. I'm really
looking forward to the replies.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Performance-issues-regarding-Delaunay-3-priority-queue-tp4658738.html
- [cgal-discuss] Performance issues regarding Delaunay_3 & priority queue, jiju peethambaran, 02/02/2014
- Re: [cgal-discuss] Performance issues regarding Delaunay_3 & priority queue, Monique Teillaud, 02/02/2014
- Re: [cgal-discuss] Performance issues regarding Delaunay_3 & priority queue, jiju peethambaran, 02/02/2014
- Re: [cgal-discuss] Performance issues regarding Delaunay_3 & priority queue, Marc Glisse, 02/02/2014
- Re: [cgal-discuss] Performance issues regarding Delaunay_3 & priority queue, jiju peethambaran, 02/03/2014
- Re: [cgal-discuss] Performance issues regarding Delaunay_3 & priority queue, Olivier Devillers, 02/02/2014
