cgal-discuss - Re: [cgal-discuss] Performance issues regarding Delaunay_3 & priority queue
  • To:
  • Subject: Re: [cgal-discuss] Performance issues regarding Delaunay_3 & priority queue
  • Date: Sun, 02 Feb 2014 19:55:54 +0100
Le 02/02/14 19:27, Marc Glisse a écrit :
On Sun, 2 Feb 2014, jiju peethambaran wrote:
Will something like storing circumradius in the tetrahedra in the
cellbase
work? Can I do that? or Can you suggest an alternative way of doing this?
All I want here is to order the tetrahedra in terms of their
circumradius...
Alpha_shape_3 already has that, I'm just not sure what the best way is
to access this information (use filtration() and ignore the simplices of
lower dimension?). Note that to compute the circumradius, computing the
circumcenter is certainly not optimal, see Compute_squared_radius_3.
If you want to order all tetrahedra, use Finite_cells_iterator instead of writing your own loops.
Note also that Compute_squared_radius_3 operates on points, so, you can avoid to construct Tetrahedron_3 objects.
If you want to cache the circumradius to avoid recomputing it several times on the same cell, you can use Triangulation_cell_base_with_info_3.
You can also probably take inspiration from the code of Triangulation_cell_base_with_circumcenter_3, which allows to cache the circumcenter, but not the circumradius.
Monique Teillaud
http://www.inria.fr/sophia/members/Monique.Teillaud/
INRIA Sophia Antipolis - Méditerranée
Institut National de Recherche en Informatique et Automatique
