cgal-discuss - Re: [cgal-discuss] Problems in running make command for CGAL-4.3
  • To:
  • Subject: Re: [cgal-discuss] Problems in running make command for CGAL-4.3
  • Date: Mon, 03 Feb 2014 12:39:13 +0100
Le Monday 03 February 2014 02:51:48 kavishrox a écrit :
> Hi,
> I am a beginner in using CGAL and trying to install it . I ran cmake .
> command and it showed the following output
> * <http://pastebin.com/p68L4ZRy> http://pastebin.com/p68L4ZRy*
> On running the make command I get the following output:
> * <http://pastebin.com/T5QKBGUE> http://pastebin.com/T5QKBGUE*
> Can anyone help me on this . I am really frustrated .
Your build log shows that your installation of Boost is not correct:
root@ubuntu:/home/kavish/Downloads/CGAL-4.3# make
Scanning dependencies of target CGAL
[ 3%] Building CXX object src/CGAL/CMakeFiles/CGAL.dir/all_files.cpp.o
In file included from
/usr/local/include/boost/numeric/conversion/numeric_cast_traits.hpp:28:0,
from /usr/local/include/boost/numeric/conversion/cast.hpp:34,
from /usr/local/include/boost/lexical_cast.hpp:159,
from
/home/kavish/Downloads/CGAL-4.3/include/CGAL/exceptions.h:28,
from
/home/kavish/Downloads/CGAL-4.3/src/CGAL/assertions.cpp:28,
from
/home/kavish/Downloads/CGAL-4.3/src/CGAL/all_files.cpp:8:
/usr/local/include/boost/numeric/conversion/detail/numeric_cast_traits.hpp:12:91:
fatal error:
boost/numeric/conversion/detail/preprocessed/numeric_cast_traits_common.hpp:
No such file or directory
#include
<boost/numeric/conversion/detail/preprocessed/numeric_cast_traits_common.hpp>
compilation terminated.
A file from your Boost installation tries to include another file that your
Boost installation does not have. There should be a file
/usr/local/include/boost/numeric/conversion/detail/preprocessed/numeric_cast_traits_common.hpp
in your Boost installation. Try to reinstall it.
Laurent Rineau, PhD
