- To: kavishrox <>
- Cc:
- Subject: Re: [cgal-discuss] Problems in running make command for CGAL-4.3
- Date: Mon, 03 Feb 2014 12:50:29 +0100
kavishrox
writes:
> Hi,
> I am a beginner in using CGAL and trying to install it . I ran cmake .
> command and it showed the following output
> * <http://pastebin.com/p68L4ZRy> http://pastebin.com/p68L4ZRy*
> On running the make command I get the following output:
> * <http://pastebin.com/T5QKBGUE> http://pastebin.com/T5QKBGUE*
It also seems a little bit odd that you are using a hand-installed
Boost, even though you are on an OS with a package manager.
The easiest way to install Boost for development on Ubuntu is:
sudo apt-get install libboost-all-dev
- [cgal-discuss] Problems in running make command for CGAL-4.3, kavishrox, 02/03/2014
- Re: [cgal-discuss] Problems in running make command for CGAL-4.3, Laurent Rineau (CGAL/GeometryFactory), 02/03/2014
- Re: [cgal-discuss] Problems in running make command for CGAL-4.3, Philipp Moeller, 02/03/2014
