- To:
- Subject: Re: [cgal-discuss] Examples not able to compile
- Date: Thu, 6 Feb 2014 20:27:24 +0530
resolved : It was my fault .. I didn't run make install .. It works fine now ..
KAVISH DWIVEDI
B.Tech (VII Sem)
INFORMATION TECHNOLOGY
MNNIT , Allahabad
B.Tech (VII Sem)
MNNIT , Allahabad
On Thu, Feb 6, 2014 at 7:57 PM, kavish dwivedi <> wrote:
Hi,I have successfully run cmake . and make install for CGAL and also installed all the required libraries but when I run "cmake -DCGAL_DIR=/home/kavish/CGAL-4.3 . " .. it gives me output as
-- This program requires the CGAL library, and will not be compiled.-- Configuring done-- Generating done-- Build files have been written to: /home/kavish/Downloads/CGAL-4.3/examples/Convex_hull_3How to get through this thing ? thanks in advance !!! The output of my make command is below just in case you think that something might be wrong there.Please help me .. I have been stuck to get cgal working properly for over a week now .
Scanning dependencies of target CGAL[ 3%] Building CXX object src/CGAL/CMakeFiles/CGAL.dir/all_files.cpp.oLinking CXX shared library ../../lib/libCGAL.so[ 3%] Built target CGALScanning dependencies of target CGAL_Core[ 6%] Building CXX object src/CGAL_Core/CMakeFiles/CGAL_Core.dir/all_files.cpp.oLinking CXX shared library ../../lib/libCGAL_Core.so[ 6%] Built target CGAL_Core[ 9%] Generating qrc_Triangulation_2.cxx[ 12%] Generating __/__/include/CGAL/Qt/moc_GraphicsViewNavigation.cxx[ 16%] Generating __/__/include/CGAL/Qt/moc_DemosMainWindow.cxx[ 19%] Generating __/__/include/CGAL/Qt/moc_GraphicsItem.cxx[ 22%] Generating __/__/include/CGAL/Qt/moc_GraphicsViewInput.cxx[ 25%] Generating qrc_CGAL.cxx[ 29%] Generating qrc_Input.cxx[ 32%] Generating qrc_File.cxxScanning dependencies of target CGAL_Qt4[ 35%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/all_files.cpp.o[ 38%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_GraphicsViewNavigation.cxx.o[ 41%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_DemosMainWindow.cxx.o[ 45%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_GraphicsItem.cxx.o[ 48%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_GraphicsViewInput.cxx.o[ 51%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/qrc_CGAL.cxx.o[ 54%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/qrc_Input.cxx.o[ 58%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/qrc_File.cxx.o[ 61%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/qrc_Triangulation_2.cxx.oLinking CXX shared library ../../lib/libCGAL_Qt4.so[ 61%] Built target CGAL_Qt4Scanning dependencies of target CGAL_ImageIO[ 64%] Building CXX object src/CGAL_ImageIO/CMakeFiles/CGAL_ImageIO.dir/all_files.cpp.oLinking CXX shared library ../../lib/libCGAL_ImageIO.so[ 64%] Built target CGAL_ImageIO[ 67%] Generating Qt_widget_OpenGL.moc[ 70%] Generating Kinetic_Qt_core.moc[ 74%] Generating Kinetic_Qt_timer.moc[ 77%] Generating Kinetic_Qt_widget_2_core.moc[ 80%] Generating Kinetic_Qt_window_2.moc[ 83%] Generating Qt_widget.moc[ 87%] Generating Qt_widget_layer.moc[ 90%] Generating Qt_widget_standard_toolbar.moc[ 93%] Generating Qt_help_window.moc[ 96%] Generating Qt_widget_history.mocScanning dependencies of target CGAL_Qt3[100%] Building CXX object src/CGAL_Qt3/CMakeFiles/CGAL_Qt3.dir/all_files.cpp.oLinking CXX shared library ../../lib/libCGAL_Qt3.so[100%] Built target CGAL_Qt3KAVISH DWIVEDI
B.Tech (VIIISem)
MNNIT , Allahabad
- [cgal-discuss] Examples not able to compile, kavish dwivedi, 02/06/2014
- Re: [cgal-discuss] Examples not able to compile, kavish dwivedi, 02/06/2014
