- To:
- Subject: [cgal-discuss] Examples not able to compile
- Date: Thu, 6 Feb 2014 19:57:13 +0530
Hi,
I have successfully run cmake . and make install for CGAL and also installed all the required libraries but when I run "cmake -DCGAL_DIR=/home/kavish/CGAL-4.3 . " .. it gives me output as
How to get through this thing ? thanks in advance !!! The output of my make command is below just in case you think that something might be wrong there.Please help me .. I have been stuck to get cgal working properly for over a week now .
-- This program requires the CGAL library, and will not be compiled.
-- Configuring done
-- Generating done
-- Build files have been written to: /home/kavish/Downloads/CGAL-4.3/examples/Convex_hull_3
Scanning dependencies of target CGAL
[ 3%] Building CXX object src/CGAL/CMakeFiles/CGAL.dir/all_files.cpp.o
Linking CXX shared library ../../lib/libCGAL.so
[ 3%] Built target CGAL
Scanning dependencies of target CGAL_Core
[ 6%] Building CXX object src/CGAL_Core/CMakeFiles/CGAL_Core.dir/all_files.cpp.o
Linking CXX shared library ../../lib/libCGAL_Core.so
[ 6%] Built target CGAL_Core
[ 9%] Generating qrc_Triangulation_2.cxx
[ 12%] Generating __/__/include/CGAL/Qt/moc_GraphicsViewNavigation.cxx
[ 16%] Generating __/__/include/CGAL/Qt/moc_DemosMainWindow.cxx
[ 19%] Generating __/__/include/CGAL/Qt/moc_GraphicsItem.cxx
[ 22%] Generating __/__/include/CGAL/Qt/moc_GraphicsViewInput.cxx
[ 25%] Generating qrc_CGAL.cxx
[ 29%] Generating qrc_Input.cxx
[ 32%] Generating qrc_File.cxx
Scanning dependencies of target CGAL_Qt4
[ 35%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/all_files.cpp.o
[ 38%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_GraphicsViewNavigation.cxx.o
[ 41%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_DemosMainWindow.cxx.o
[ 45%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_GraphicsItem.cxx.o
[ 48%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_GraphicsViewInput.cxx.o
[ 51%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/qrc_CGAL.cxx.o
[ 54%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/qrc_Input.cxx.o
[ 58%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/qrc_File.cxx.o
[ 61%] Building CXX object src/CGAL_Qt4/CMakeFiles/CGAL_Qt4.dir/qrc_Triangulation_2.cxx.o
Linking CXX shared library ../../lib/libCGAL_Qt4.so
[ 61%] Built target CGAL_Qt4
Scanning dependencies of target CGAL_ImageIO
[ 64%] Building CXX object src/CGAL_ImageIO/CMakeFiles/CGAL_ImageIO.dir/all_files.cpp.o
Linking CXX shared library ../../lib/libCGAL_ImageIO.so
[ 64%] Built target CGAL_ImageIO
[ 67%] Generating Qt_widget_OpenGL.moc
[ 70%] Generating Kinetic_Qt_core.moc
[ 74%] Generating Kinetic_Qt_timer.moc
[ 77%] Generating Kinetic_Qt_widget_2_core.moc
[ 80%] Generating Kinetic_Qt_window_2.moc
[ 83%] Generating Qt_widget.moc
[ 87%] Generating Qt_widget_layer.moc
[ 90%] Generating Qt_widget_standard_toolbar.moc
[ 93%] Generating Qt_help_window.moc
[ 96%] Generating Qt_widget_history.moc
Scanning dependencies of target CGAL_Qt3
[100%] Building CXX object src/CGAL_Qt3/CMakeFiles/CGAL_Qt3.dir/all_files.cpp.o
Linking CXX shared library ../../lib/libCGAL_Qt3.so
[100%] Built target CGAL_Qt3
KAVISH DWIVEDI
B.Tech (VII
INFORMATION TECHNOLOGY
MNNIT , Allahabad
B.Tech (VII
I
Sem)INFORMATION TECHNOLOGY
MNNIT , Allahabad
- [cgal-discuss] Examples not able to compile, kavish dwivedi, 02/06/2014
- Re: [cgal-discuss] Examples not able to compile, kavish dwivedi, 02/06/2014
