cgal-discuss - Re: [cgal-discuss] Intersections of Triangle_3
  • To:
  • Subject: Re: [cgal-discuss] Intersections of Triangle_3
  • Date: Tue, 11 Feb 2014 18:33:52 +0100
On 02/08/2014 07:37 PM, Roger Mason wrote:
Hello, I want to find the segments along which Triangle_3's intersect. I
am modelling this on:
http://doc.cgal.org/latest/Kernel_23/group__intersection__linear__grp.html";>http://doc.cgal.org/latest/Kernel_23/group__intersection__linear__grp.html
So far I have: template void foo( Triangle_3& a, Triangle_3& b) {
std::cout << "The objects are: " << a << " and " << b << std::endl;
CGAL::cpp11::result_of<K::Intersect_3(Triangle_3<R>, Triangle_3)>::type
result = intersection(a, b); } I call foo like this: int main () { .....
// Now find the Triangle_3:Triangle_3 intersections. // Example Point_3
p = Point_3(0.3,0.4,0.5); Point_3 q = Point_3(0.4,0.5,0.6); Point_3 r =
Point_3(0.5,0.6,0.7); Triangle_3 t = Triangle_3(p,q,r); Point_3 pp =
Point_3(0.3,0.4,0.5); Point_3 qq = Point_3(0.4,0.5,0.6); Point_3 rr =
Point_3(0.5,0.6,0.7); Triangle_3 tt = Triangle_3(pp,qq,rr); foo(t,tt);
.... } I get this error when compiling: error: ‘Triangle_3 {aka
CGAL::Triangle_3<CGAL::Cartesian<double> >}’ is not a template Thanks
for any help. Roger
View this message in context: Intersections of Triangle_3
<http://cgal-discuss.949826.n4.nabble.com/Intersections-of-Triangle-3-tp4658788.html>
Sent from the cgal-discuss mailing list archive
<http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
Could you check the end of line of your post.
Thanks,
Sebastien.
