cgal-discuss - [cgal-discuss] problem with mpfr
  • To:
  • Subject: [cgal-discuss] problem with mpfr
  • Date: Thu, 13 Feb 2014 15:41:43 +0530
Hi All !!
I was trying to generate "OFF" FILE from a text of points as input for mesh generation.
I am getting a compile error.
What does this error mean? I have installed gmp and mpfr.
I generated Delaunay on QT Framework previously...all of them worked fine when I used them from demo file in CGAL.
But when I tried writing the code delaunay.cpp Im getting this error.
Does this error mean I haven't installed MPFR or should I do something else?
Kindly  help.
Below is the error that I got.
1>------ Build started: Project: delaunay, Configuration: Release Win32 ------
1>Build started 2/13/2014 11:34:48 AM.
1>InitializeBuildStatus:
1>  Touching "Release\delaunay.unsuccessfulbuild".
1>ClCompile:
1>  All outputs are up-to-date.
1>  stdafx.cpp
1>  delaunay.cpp
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(136): error C2146: syntax error : missing ';' before identifier 'mpfr_exp_t'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(136): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(146): error C2146: syntax error : missing ';' before identifier '_mpfr_exp'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(146): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(147): error C2143: syntax error : missing ';' before '*'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(147): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(171): error C2146: syntax error : missing ';' before identifier '__mpfr_struct'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(171): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(234): error C2146: syntax error : missing ';' before identifier '__gmp_const'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(234): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(234): error C2628: '__gmp_const' followed by 'char' is illegal (did you forget a ';'?)
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(235): error C2146: syntax error : missing ';' before identifier '__gmp_const'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(235): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(235): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>          C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(234) : see declaration of '__GMP_DECLSPEC'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(235): error C2628: '__gmp_const' followed by 'char' is illegal (did you forget a ';'?)
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(236): error C2144: syntax error : 'int' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(236): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(236): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(237): error C2144: syntax error : 'int' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(237): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(237): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(239): error C2146: syntax error : missing ';' before identifier 'mpfr_exp_t'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(239): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(239): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(239): error C2146: syntax error : missing ';' before identifier 'mpfr_get_emin'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(239): error C2086: 'int mpfr_exp_t' : redefinition
1>          C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(136) : see declaration of 'mpfr_exp_t'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(240): error C2144: syntax error : 'int' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(240): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(240): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(241): error C2146: syntax error : missing ';' before identifier 'mpfr_exp_t'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(241): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(241): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(241): error C2146: syntax error : missing ';' before identifier 'mpfr_get_emin_min'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(241): error C2086: 'int mpfr_exp_t' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(242): error C2146: syntax error : missing ';' before identifier 'mpfr_exp_t'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(242): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(242): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(242): error C2146: syntax error : missing ';' before identifier 'mpfr_get_emin_max'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(242): error C2086: 'int mpfr_exp_t' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(243): error C2146: syntax error : missing ';' before identifier 'mpfr_exp_t'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(243): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(243): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(243): error C2146: syntax error : missing ';' before identifier 'mpfr_get_emax'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(243): error C2086: 'int mpfr_exp_t' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(244): error C2144: syntax error : 'int' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(244): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(244): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(245): error C2146: syntax error : missing ';' before identifier 'mpfr_exp_t'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(245): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(245): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(245): error C2146: syntax error : missing ';' before identifier 'mpfr_get_emax_min'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(245): error C2086: 'int mpfr_exp_t' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(246): error C2146: syntax error : missing ';' before identifier 'mpfr_exp_t'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(246): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(246): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(246): error C2146: syntax error : missing ';' before identifier 'mpfr_get_emax_max'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(246): error C2086: 'int mpfr_exp_t' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(248): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(248): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(248): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(249): error C2146: syntax error : missing ';' before identifier 'mpfr_rnd_t'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(249): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(249): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(250): error C2146: syntax error : missing ';' before identifier '__gmp_const'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(250): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(250): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(250): error C2628: '__gmp_const' followed by 'char' is illegal (did you forget a ';'?)
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(253): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(253): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(253): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(254): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(254): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(254): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(255): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(255): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(255): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(256): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(256): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(256): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(257): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(257): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(257): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(258): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(258): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(258): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(260): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(260): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(260): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(261): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(261): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(261): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(262): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(262): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(262): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(263): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(263): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(263): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(264): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(264): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(264): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(266): error C2144: syntax error : 'int' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(266): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(266): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(267): error C2144: syntax error : 'int' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(267): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(267): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(268): error C2144: syntax error : 'int' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(268): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(268): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(269): error C2144: syntax error : 'int' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(269): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(269): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(270): error C2144: syntax error : 'int' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(270): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(270): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(273): error C2144: syntax error : 'int' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(273): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(273): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(275): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(275): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(275): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(276): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(276): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(276): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(277): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(277): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(277): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(280): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(280): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(280): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(282): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(282): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(282): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(284): error C2144: syntax error : 'void' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(284): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(284): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(287): error C2144: syntax error : 'int' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(287): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(287): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(289): error C2144: syntax error : 'int' should be preceded by ';'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(289): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(289): error C2086: 'int __GMP_DECLSPEC' : redefinition
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(290): error C2275: 'mpfr_rnd_t' : illegal use of this type as an _expression_
1>          C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(93) : see declaration of 'mpfr_rnd_t'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(290): error C2275: 'mpfr_prec_t' : illegal use of this type as an _expression_
1>          C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(120) : see declaration of 'mpfr_prec_t'
1>C:\Program Files\CGAL-4.2-beta1\auxiliary\gmp\include\mpfr.h(290): fatal error C1003: error count exceeds 100; stopping compilation
1>
1>Build FAILED.
1>
1>Time Elapsed 00:00:07.29
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
