cgal-discuss - Re: [cgal-discuss] problem with mpfr
  • To: Gopichand Paturi <>
  • Cc:
  • Subject: Re: [cgal-discuss] problem with mpfr
  • Date: Thu, 13 Feb 2014 11:22:11 +0100
Gopichand Paturi
writes:
> Hi All !!
> I was trying to generate "OFF" FILE from a text of points as input for mesh
> generation.
> I am getting a compile error.
> What does this error mean? I have installed gmp and mpfr.
> I generated Delaunay on QT Framework previously...all of them worked fine
> when I used them from demo file in CGAL.
> But when I tried writing the code delaunay.cpp Im getting this error.
> Does this error mean I haven't installed MPFR or should I do something else?
> Kindly help.
> Below is the error that I got.
Which compiler and CGAL version are you using?
[...snipped error messages...]
