Re: [cgal-discuss] finding cells made by neighbour points of a query point inserted in delaunay triangulation
- To:
- Subject: Re: [cgal-discuss] finding cells made by neighbour points of a query point inserted in delaunay triangulation
- Date: Fri, 21 Feb 2014 13:27:57 +0100
If you want associate info (temperature in you case) to your points, you can have a look at this example:
http://doc.cgal.org/latest/Triangulation_3/index.html#Triangulation_3UsinganIteratorOverPairs
To get the neighbor vertices without inserting a point, you need to first locate the point in the triangulation:
http://doc.cgal.org/latest/Triangulation_3/classCGAL_1_1Triangulation__3.html#adae217a7db65ecdc2405658b661ccf0a
and you can get the conflict zone using find_conflicts:
http://doc.cgal.org/latest/Triangulation_3/classCGAL_1_1Delaunay__triangulation__3.html#a24b378be12e92562ec95b65a5fa5516f
If you insert the points, then you can use the function adjacent_vertices:
http://doc.cgal.org/latest/Triangulation_3/classCGAL_1_1Triangulation__3.html#ae6f24355946f91b3618188da06d8047e
Sebastien.
On 02/21/2014 12:46 PM, sushil wrote:
Hello all,
I am very new to CGAL so i dont know much of it. I have 1008 3D points
containing some values at each of these points(in my example these are
temperatures), of which a delaunay triangulation T is created. Now the
triangulation consists of 6550 cells or tetrahedrons and i also got the
vertices of these cells using Cell_iterator and Cell_handle. Now i am
inserting a query point into this triangulation whose coordinates are known
and i want to get the temperature value at that point by linear
interpolation. i got 16 neighbour points to this query point. Now i want to
know that, for finding interpolation weights , again cells are formed using
these 16 neighbour points? if yes, i want to know how to get them and there
vertices. Also it would be a great help if somebody would explain me what
exactly is done after finding neighbour points of the query point to get an
interpolation.
Any help would be deeply appreciated.
sushil
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/finding-cells-made-by-neighbour-points-of-a-query-point-inserted-in-delaunay-triangulation-tp4658835.html
- [cgal-discuss] finding cells made by neighbour points of a query point inserted in delaunay triangulation, sushil, 02/21/2014
- Re: [cgal-discuss] finding cells made by neighbour points of a query point inserted in delaunay triangulation, Sebastien Loriot (GeometryFactory), 02/21/2014
