Re: [cgal-discuss] finding cells made by neighbour points of a query point inserted in delaunay triangulation
- To:
- Subject: Re: [cgal-discuss] finding cells made by neighbour points of a query point inserted in delaunay triangulation
- Date: Fri, 21 Feb 2014 04:56:08 -0800 (PST)
If you want associate info (temperature in you case) to your points, you
can have a look at this example:
http://doc.cgal.org/latest/Triangulation_3/index.html#Triangulation_3UsinganIteratorOverPairs
To get the neighbor vertices without inserting a point, you need to
first locate the point in the triangulation:
http://doc.cgal.org/latest/Triangulation_3/classCGAL_1_1Triangulation__3.html#adae217a7db65ecdc2405658b661ccf0a
and you can get the conflict zone using find_conflicts:
http://doc.cgal.org/latest/Triangulation_3/classCGAL_1_1Delaunay__triangulation__3.html#a24b378be12e92562ec95b65a5fa5516f
If you insert the points, then you can use the function adjacent_vertices:
http://doc.cgal.org/latest/Triangulation_3/classCGAL_1_1Triangulation__3.html#ae6f24355946f91b3618188da06d8047e
Thanks, sebastien for your reply. But i want to know what is done after
finding neighbours to the query point. I suppose again the triangulation is
done with these 16 neighbour points. i want to know how to get the cells of
this triangulation containing 16 points?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/finding-cells-made-by-neighbour-points-of-a-query-point-inserted-in-delaunay-triangulation-tp4658835p4658837.html
- [cgal-discuss] finding cells made by neighbour points of a query point inserted in delaunay triangulation, sushil, 02/21/2014
- Re: [cgal-discuss] finding cells made by neighbour points of a query point inserted in delaunay triangulation, Sebastien Loriot (GeometryFactory), 02/21/2014
- Re: [cgal-discuss] finding cells made by neighbour points of a query point inserted in delaunay triangulation, sushil, 02/21/2014
