- To:
- Subject: [cgal-discuss] Creating a surface from points
- Date: Sun, 9 Mar 2014 16:39:45 -0700 (PDT)
Hi,
Is it possible to create a surface(Polyhedron_3), if the only information I
have available are the points that should lie on the surface. This is
different from make_surface_mesh function as you need to pass an already
existing surface to the function. In my case, all I have is a bunch of
points and I am looking to create a surface from those points.
Thanks,
Piyush Gupta
Piyush Gupta
UIUC
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Creating-a-surface-from-points-tp4658933.html
- [cgal-discuss] Creating a surface from points, gupta61, 03/10/2014
- Re: [cgal-discuss] Creating a surface from points, Sebastien Loriot (GeometryFactory), 03/10/2014
- Re: [cgal-discuss] Creating a surface from points, gupta61, 03/10/2014
- Re: [cgal-discuss] Creating a surface from points, Rémi Cura, 03/10/2014
- Re: [cgal-discuss] Creating a surface from points, Sebastien Loriot (GeometryFactory), 03/11/2014
