Re: [cgal-discuss] Stack overflow error - dD Convex Hulls and Delaunay Triangulations - CGAL
- To:
- Subject: Re: [cgal-discuss] Stack overflow error - dD Convex Hulls and Delaunay Triangulations - CGAL
- Date: Mon, 10 Mar 2014 20:41:23 +0200
On Mon, Mar 10, 2014 at 6:40 PM, Marc Glisse <> wrote:
On Mon, 10 Mar 2014, Muhammad Abdelghaffar wrote:1.3G is getting big indeed... On linux your program works with a stack of 130M (didn't try anything between 8M (not enough) and 130M) and creates a 2G output file. Did you compile as 64 bits?
On Sun, Mar 9, 2014 at 1:10 AM, Marc Glisse <> wrote:
On Sat, 8 Mar 2014, Muhammad Abdelghaffar wrote:
I'm trying to construct the delaunay graph for a
point set in $d=6$ using
the CGAL dD Convex Hulls and Delaunay Triangulations
package , but I'm
getting a stack overflow error.
Did you try increasing the stack size? In case it might be related to:
http://stackoverflow.com/q/17404432/1918193
Ok. I've tried to increase the stack reserve/commit size up to 1.3 GB, the
overflow now happens at a later stage, but still happens.
No. 32 bits. Will this fix this recursion bug ?
I don't use that platform so I can't tell. Maybe it only shows the heap size? Maybe it refused to set the stack size to your value?The Task Manager shows that the code is only using ~700 MB, shouldn't this value be the one I've set ?
That all it shows? It isn't being very helpful... Ideally it would show that we currently have visibility_search calling itself recursively with a depth of thousands, like it does on linux.
Also, could you show what the call stack looks like at the time
of the overflow?
Please find the attachment.
Yes, you are right .. this was just before the overflow. When the overflow happened VS crashed as I was trying to see how the call stack looks like. I did set a counter in the visibility_search function to see its depth of recursion. The counter was 2964 using the default 1MB stack size.
Delaunay_2 and Delaunay_3 are better. I don't have any experience with Delaunay_d, see if there are performance statements in the doc...
I have another question, is this package surpasses Qhull's performance in
terms of speed and memory ?
Qhull consumed ~250 MBs for the same point set, and did't crash. Since CGAL's package used ~700 MBs and crashed, I think qhull is better than Delaunay_d in higher dimensions
The num_of_unbounded_simplices issue is strange, the number becomes negative with just a few vertices. Good thing is, that number doesn't seem to be used for anything, so unless you have other issues, you can just ignore it.
Marc Glisse
Regards,
Muhammad
- [cgal-discuss] Stack overflow error - dD Convex Hulls and Delaunay Triangulations - CGAL, Muhammad Abdelghaffar, 03/08/2014
- Re: [cgal-discuss] Stack overflow error - dD Convex Hulls and Delaunay Triangulations - CGAL, Marc Glisse, 03/09/2014
- Re: [cgal-discuss] Stack overflow error - dD Convex Hulls and Delaunay Triangulations - CGAL, Muhammad Abdelghaffar, 03/10/2014
- Re: [cgal-discuss] Stack overflow error - dD Convex Hulls and Delaunay Triangulations - CGAL, Marc Glisse, 03/10/2014
