Re: [cgal-discuss] Stack overflow error - dD Convex Hulls and Delaunay Triangulations - CGAL
- To:
- Subject: Re: [cgal-discuss] Stack overflow error - dD Convex Hulls and Delaunay Triangulations - CGAL
- Date: Mon, 10 Mar 2014 17:40:31 +0100 (CET)
On Mon, 10 Mar 2014, Muhammad Abdelghaffar wrote:
On Sun, Mar 9, 2014 at 1:10 AM, Marc Glisse
wrote:
On Sat, 8 Mar 2014, Muhammad Abdelghaffar wrote:
I'm trying to construct the delaunay graph for a
point set in $d=6$ using
the CGAL dD Convex Hulls and Delaunay Triangulations
package , but I'm
getting a stack overflow error.
Did you try increasing the stack size? In case it might be related to:
http://stackoverflow.com/q/17404432/1918193
Ok. I've tried to increase the stack reserve/commit size up to 1.3 GB, the
overflow now happens at a later stage, but still happens.
1.3G is getting big indeed... On linux your program works with a stack of 130M (didn't try anything between 8M (not enough) and 130M) and creates a 2G output file. Did you compile as 64 bits?
The Task Manager shows that the code is only using ~700 MB, shouldn't this value be the one I've set ?
I don't use that platform so I can't tell. Maybe it only shows the heap size? Maybe it refused to set the stack size to your value?
Also, could you show what the call stack looks like at the time
of the overflow?
Please find the attachment.
That all it shows? It isn't being very helpful... Ideally it would show that we currently have visibility_search calling itself recursively with a depth of thousands, like it does on linux.
I have another question, is this package surpasses Qhull's performance in
terms of speed and memory ?
Delaunay_2 and Delaunay_3 are better. I don't have any experience with Delaunay_d, see if there are performance statements in the doc...
The num_of_unbounded_simplices issue is strange, the number becomes negative with just a few vertices. Good thing is, that number doesn't seem to be used for anything, so unless you have other issues, you can just ignore it.
Marc Glisse
- [cgal-discuss] Stack overflow error - dD Convex Hulls and Delaunay Triangulations - CGAL, Muhammad Abdelghaffar, 03/08/2014
- Re: [cgal-discuss] Stack overflow error - dD Convex Hulls and Delaunay Triangulations - CGAL, Marc Glisse, 03/09/2014
- Re: [cgal-discuss] Stack overflow error - dD Convex Hulls and Delaunay Triangulations - CGAL, Muhammad Abdelghaffar, 03/10/2014
- Re: [cgal-discuss] Stack overflow error - dD Convex Hulls and Delaunay Triangulations - CGAL, Marc Glisse, 03/10/2014
