- To:
- Subject: [cgal-discuss] Problems with Triangulated Surface Mesh Simplification
- Date: Fri, 21 Mar 2014 11:13:41 +0200
Hi,
I am trying to compile an simplification functionality that follow the examples at http://www.cgal.org/Manual/4.2/doc_html/cgal_manual/Surface_mesh_simplification/Chapter_main.html#Subsection_53.4.2Exact error messages:
In file included from /usr/include/CGAL/boost/graph/graph_traits_HalfedgeDS.h:25:0,
from /usr/include/CGAL/boost/graph/graph_traits_Polyhedron_3.h:23,
from /usr/include/CGAL/Surface_mesh_simplification/HalfedgeGraph_Polyhedron_3.h:23,
from cloud2volume.cpp:58:
/usr/include/boost/graph/graph_traits.hpp: In instantiation of ‘struct boost::graph_traits<const PolyhedralSurface>’:
simplify.h:126:67: required from ‘class Constrains_border_map<PolyhedralSurface>’
simplify.h:522:31: required from ‘void simplify_border_and_surface(P_&, const std::set<typename P_::Vertex_handle>&) [with ...]’
extract_polyhedron.h:2004:72: required from here
/usr/include/boost/graph/graph_traits.hpp:57:52: error: no type named ‘vertex_descriptor’ in ‘const class PolyhedralSurface’
typedef typename G::vertex_descriptor vertex_descriptor;
/usr/include/boost/graph/graph_traits.hpp:58:52: error: no type named ‘edge_descriptor’ in ‘const class PolyhedralSurface’
typedef typename G::edge_descriptor edge_descriptor;
If I change at Constraint property map from
typedef typename boost::graph_traits<P_ const>::edge_descriptor edge_type;to
typedef typename CGAL::HDS_graph_traits<P_ const>::edge_descriptor edge_type;
it fixes errors mentioned above, but then errors are generated at CGAL code:
In file included from /usr/include/CGAL/Surface_mesh_simplification/Policies/Edge_collapse/Midpoint_and_length.h:22:0,
from cloud2volume.cpp:62:
/usr/include/CGAL/Surface_mesh_simplification/Policies/Edge_collapse/Edge_length_cost.h: In instantiation of ‘class CGAL::Surface_mesh_simplification::Edge_length_cost<PolyhedralSurface>’:
simplify.h:533:86: required from ‘void simplify_border_and_surface(P_&, const std::set<typename P_::Vertex_handle>&) [with ...]’
/usr/include/CGAL/Surface_mesh_simplification/Policies/Edge_collapse/Edge_length_cost.h:43:54: error: invalid use of incomplete type ‘struct CGAL::halfedge_graph_traits<PolyhedralSurface>’
typedef typename halfedge_graph_traits<ECM>::Point Point ;
My Ubuntu packages are
- CGAL 4.2
- boost 1.53
I have previously used surface simplification code with older CGAL library, but this is the first time I got this kind error :O
Any suggestions for a fix?
Matti L
Life is complex. It has real and imaginary parts.
- [cgal-discuss] Problems with Triangulated Surface Mesh Simplification, Matti Lehtonen, 03/21/2014
- Re: [cgal-discuss] Problems with Triangulated Surface Mesh Simplification, Zohar, 03/23/2014
- Re: [cgal-discuss] Problems with Triangulated Surface Mesh Simplification, Matti Lehtonen, 03/26/2014
- Re: [cgal-discuss] Problems with Triangulated Surface Mesh Simplification, Zohar, 03/27/2014
- Re: [cgal-discuss] Problems with Triangulated Surface Mesh Simplification, Matti Lehtonen, 03/28/2014
- Re: [cgal-discuss] Problems with Triangulated Surface Mesh Simplification, Matti Lehtonen, 03/31/2014
- Re: [cgal-discuss] Problems with Triangulated Surface Mesh Simplification, Zohar, 03/31/2014
