cgal-discuss - Re: [cgal-discuss] Problems with Triangulated Surface Mesh Simplification
  • To:
  • Subject: Re: [cgal-discuss] Problems with Triangulated Surface Mesh Simplification
  • Date: Mon, 31 Mar 2014 12:18:38 +0300
Hi,
On 27 March 2014 03:19, Zohar <> wrote:
Anyway, about the last linkage error, it seems a different type. But maybe
if you provide a minimal code that reproduces it, I might play with it a
bit.
Fixed. Apparently, an old piece of code became suddenly invalid by newer version of linker. The function where the edge collapse were called, has a parameter, which type were an abstract base class for simplification termination decision classes. => Now worth of an error at link phase. Fixed by using the class as a template parameter.
Matti L
Life is complex. It has real and imaginary parts.
