- To:
- Subject: [cgal-discuss] Error while using make_surface_mesh
- Date: Fri, 21 Mar 2014 15:26:48 -0700 (PDT)
Hi,
I am getting this error while trying to use make_surface_mesh function
terminate called after throwing an instance of
'CGAL::Precondition_exception'
what(): CGAL ERROR: precondition violation!
Expr: ! k.is_degenerate_3_object()(t)
From what I understand, this is possible when I have a degenerate segment.
But I checked all the points I am inserting for the surface and there are no
degenerate segments. I was wondering if you can shed some light on this
matter and other cases where it is possible to get this error. Thanks.
Regards,
Piyush Gupta
Piyush Gupta
UIUC
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Error-while-using-make-surface-mesh-tp4658997.html
- [cgal-discuss] Error while using make_surface_mesh, gupta61, 03/21/2014
- Re: [cgal-discuss] Error while using make_surface_mesh, Laurent Rineau (CGAL/GeometryFactory), 03/31/2014
