- To:
- Subject: [cgal-discuss] CGAL::intersection()
- Date: Tue, 25 Mar 2014 11:30:46 +0100
Hi!
I tried to compute the intersection of two triangles but the result
can't be assigned to any of the types named in the documentation,
see the minimal example below. Any hints?
#include <fstream>
#include <string.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::Point_3 Point_3;
typedef K::Triangle_3 Triangle_3;
typedef K::Segment_3 Segment_3;
typedef K::Line_3 Line_3;
typedef K::Vector_3 Vector_3;
typedef K::Plane_3 Plane_3;
using namespace std;
int main(int argc,char* argv[])
Point_3 p0(5067.44,429.864,1191.84);
Point_3 p1(5069.42,430.425,1191.38);
Point_3 p2(5069.03,431.185,1192.48);
Triangle_3 t0(p0,p1,p2);
Point_3 p3(5071.17,432.114,1192.12);
Triangle_3 t1(p3,p2,p1);
if(!CGAL::do_intersect(t0,t1)) return 0;
cout<<"Intersection of two triangles:"<<endl;
cout<<t0<<endl;
cout<<t1<<endl;
CGAL::Object obj(CGAL::intersection(t0,t1));
Segment_3 iss;
Point_3 isp;
std::vector<Point_3> vIsps;
Triangle_3 ist;
if(CGAL::assign(iss,obj)) cout<<"segment"<<endl;
else if(CGAL::assign(isp,obj)) cout<<"point"<<endl;
else if(CGAL::assign(vIsps,obj)) cout<<"vector of points"<<endl;
else if(CGAL::assign(ist,obj)) cout<<"triangle"<<endl;
else cout<<"BUG BUG BUG"<<endl;
return 0;
Best regards
Bernhard Kornberger
- [cgal-discuss] CGAL::intersection(), Bernhard Kornberger, 03/25/2014
- Re: [cgal-discuss] CGAL::intersection(), Sebastien Loriot (GeometryFactory), 03/25/2014
- Re: [cgal-discuss] CGAL::intersection(), Bernhard Kornberger, 03/25/2014
