cgal-discuss - Re: [cgal-discuss] CGAL::intersection()
  • To:
  • Subject: Re: [cgal-discuss] CGAL::intersection()
  • Date: Tue, 25 Mar 2014 13:09:20 +0100
On 03/25/2014 12:00 PM, Sebastien Loriot (GeometryFactory) wrote:
Hi Bernhard,
I'm sure you are aware of:
http://www.cgal.org/FAQ.html#inexact_NT
This intersection code is rather naive and make use of
constructions to determine the intersection. That is to
say it does check if the triangles have a common edge.
However, there are several ways to handle the issue depending
on the context you are using this code without having to resort
to exact arithmetic.
Best,
Sebastien.
PS: if you are using CGAL 4.3 there was a bug in this function fixed in
4.4 http://www.cgal.org/releases.html#release4.4
Sure, thats it. I wrote _inexact_constructions. It works now. Thank
you, Sebastien.
Best
Bernhard
