- To:
- Cc: Yann Cobigo <>
- Subject: Re: [cgal-discuss] Tetrahedral mesh viewer
- Date: Tue, 25 Mar 2014 17:16:49 +0100
Le Tuesday 18 March 2014 03:15:58 Yann Cobigo a écrit :
> Hi Laurent,
> I installed fedora 20 on my system and 32 bits version of libGL.so.1 (from
> NVIDIA drivers) and it still does not work ...
> lddmedit-linux
> linux-gate.so.1 => (0xf7773000)
> libGL.so.1 => /lib/libGL.so.1 (0xf763c000)
> libGLU.so.1 => /lib/libGLU.so.1 (0xf75b3000)
> libXext.so.6 => /lib/libXext.so.6 (0xf75a0000)
> libX11.so.6 => /lib/libX11.so.6 (0xf7463000)
> libm.so.6 => /lib/libm.so.6 (0xf741c000)
> libc.so.6 => /lib/libc.so.6 (0xf725e000)
> libpthread.so.0 => /lib/libpthread.so.0 (0xf7243000)
> libnvidia-tls.so.331.49 => /lib/libnvidia-tls.so.331.49 (0xf723f000)
> libnvidia-glcore.so.331.49 => /lib/libnvidia-glcore.so.331.49 (0xf4ff9000)
> libdl.so.2 => /lib/libdl.so.2 (0xf4ff4000)
> libstdc++.so.6 => /lib/libstdc++.so.6 (0xf4f08000)
> libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xf4eeb000)
> libxcb.so.1 => /lib/libxcb.so.1 (0xf4ec7000)
> /lib/ld-linux.so.2 (0xf7774000)
> libXau.so.6 => /lib/libXau.so.6 (0xf4ec3000)
> Do you have any other suggestion? I am assuming medit sources are not
> available.
> Best regards,
> Yann
> On Tuesday, December 3, 2013 4:01 PM, Yann Cobigo
> wrote:
> Hi Laurent,
> Thank you for your response. I had the libraries 32bit already installed:
> ldd medit-linux
> linux-gate.so.1 => (0xf77df000)
> libGL.so.1 => /usr/lib/libGL.so.1 (0xf7702000)
Here you should have:
libGL.so.1 => /usr/lib/nvidia/libGL.so.1
Do you have the file /etc/ld.so.conf.d/nvidia-lib.conf, and what is its
content? On my Fedora 19, it is contains a single line:
/usr/lib/nvidia
Laurent Rineau, PhD
- Re: [cgal-discuss] Tetrahedral mesh viewer, Yann Cobigo, 03/18/2014
- Re: [cgal-discuss] Tetrahedral mesh viewer, Laurent Rineau (CGAL/GeometryFactory), 03/25/2014
- Re: [cgal-discuss] Tetrahedral mesh viewer, Yann Cobigo, 03/25/2014
