cgal-discuss - [cgal-discuss] CGAL dD Delaunay Problem
  • To: "" <>
  • Subject: [cgal-discuss] CGAL dD Delaunay Problem
  • Date: Tue, 25 Mar 2014 17:56:38 +0000
  • Accept-language: en-US
Dear Sir or Madam,
I am not sure if I have made an error or if there is a bug in CGAL dD Delaunay package. I need to do Delaunay triangulation of some three-dimensional points and need to generalize the code to other dimensions later. So I wrote this code:
double coord[] = {
15.987446522913068, 27.202164077804600, -1.7503256142623180,
15.783731654803892, 27.268252018459251, -1.7667168014850418,
15.366332754158634, 25.364059942735178, -0.12067529139448278,
14.798358756496864, 25.645272186454374, -0.24621719891310628,
14.416741390968623, 26.534931393517535, -0.90761123478229566,
12.653889524424551, 30.356776464885129, 1.6780311801981169,
20.141382962264476, 29.666174471723380, 0.81578848925181291,
15.255480206458079, 32.065555891106911, 0.14008969527418605,
15.856413673274881, 31.537804468497811, -0.50108136475224174,
19.537758401022533, 29.790220202824923, -0.21754568768545338,
19.418171028905622, 29.790007422401796, -0.38830723957693186,
20.081590302704605, 29.854788525235321, 0.73931846754153374,
16.096713953744956, 24.603235225447076, 1.9663067370703267,
15.057336655250380, 24.912757478035189, 2.7258085800022718,
19.717425535978570, 27.248357239016887, 3.5216075631300305,
20.340124881568187, 28.287915509305925, 2.9881740318160834,
18.440406384399445, 28.756603149763084, 5.7274305773261025,
19.732584195169082, 29.437336063389296, 4.1695063361795697,
16.615174375063219, 32.278894713132360, 2.6796054812782928,
19.411374934889903, 30.874452428442833, 2.6765292926211286,
15.527857372851596, 31.342303101257738, 4.4163514428924291,
17.970992967584714, 28.796276720304878, 5.9574834972343362,
14.323514965294358, 26.455018287900284, 4.7555968341210084,
12.748877146187398, 30.055258023558022, 3.4117720135679241,
#include <CGAL/Cartesian_d.h>
#include <CGAL/Kernel_d/Sphere_d.h>
#include <CGAL/Delaunay_d.h>
#include <iostream>
#include <list>
typedef CGAL::Cartesian_d<double> Kernel;
typedef CGAL::Delaunay_d<Kernel> Delaunay;
typedef Delaunay::Vertex_handle Vertex_handle;
typedef Delaunay::Simplex_handle Simplex_handle;
typedef Delaunay::Point_d Point;
int main()
                Delaunay De(3);
                for(int i=0; i<24; i++)
                                Point p(3, coord+i*3, coord+i*3+3);
                                De.insert(p);
                std::list<Simplex_handle> simplices = De.all_simplices();
                std::cout<<simplices.size();
                return 0;
When I run this program on a Windows Server 2012 machine using Visual Studio 2012 compiler, the output I get is:
3
The problem is, if one plot the coordinates using MATLAB, one can clearly see that those points form a polygon and the Delaunay triangulation should consist of way more than 3 simplices. But why does the program only find 3 simplices?
Best,
Ge Zhang
